12-31-2010, 07:59 PM | #1 |
Smell of Gas
so, im working on a running project.
I start my Model A up every once in a while and take her on a run down the block....by the time i get out im very light headed. While driving i always smell a light flume of gas. is this normal? |
12-31-2010, 08:05 PM | #2 |
Re: Smell of Gas
Check for dampness at the steering column brace which is attached to the bottom of the tank. Also check the fittings that feed gas through the firewall.
12-31-2010, 08:07 PM | #3 |
Re: Smell of Gas
No, that is not normal. You might check the bottom of the gas tank behind the steering column support bracket. Mine was seeping just enough to keep the area damp but never dripped.
12-31-2010, 08:09 PM | #4 |
Re: Smell of Gas
thanks for the tips guys, il go out and check.
12-31-2010, 08:12 PM | #5 |
Re: Smell of Gas
i wanted to ask also, if its leaking around the steering brace...is the gas tankshot?or can welding patch it up?
12-31-2010, 08:18 PM | #6 |
Re: Smell of Gas
12-31-2010, 08:44 PM | #7 |
Re: Smell of Gas
It has been my experience that the 28 - 29 tanks will crack and seep around the perimeter at and through where the rolling spot weld holds the top and bottom stampings together. Gar Williams
12-31-2010, 08:55 PM | #8 |
Re: Smell of Gas
Also check around the gas gauge.
Alan 1930 Cabriolet (the newest project) 1929 Special Coupe (pieces n parts) 1928 Sport Coupe (the driver) |
12-31-2010, 11:48 PM | #9 |
Re: Smell of Gas
06-16-2012, 10:44 AM | #10 |
Re: Smell of Gas
I have the same issue but I only smell it going down the road. If the tank is leaking wouldnt you smell it all the time?
06-16-2012, 10:50 AM | #11 |
Re: Smell of Gas
Also, check your exhaust manifold and clamp for a leak, breathing carbon monoxide will make you lightheaded, you may not smell it if it's coming inside.
06-16-2012, 12:43 PM | #12 |
Re: Smell of Gas
On my 31 when using the "air conditioner" feature on the windshield if I open it all the way I will get gas fumes inside, at the notch, or 1/2 way no fumes.
08-26-2012, 11:21 AM | #13 |
Re: Smell of Gas
It turned out to be the gas guage gasket. It was almost new 9the rubber type) and the eythenol in the gas destroyed it.
08-26-2012, 12:11 PM | #14 |
Re: Smell of Gas
Use the cork gaskets. JMO
Paul in CT |
08-26-2012, 01:33 PM | #15 |
Re: Smell of Gas
A crack could be welded by someone with skill, soldered by someone good at soldering. But it may be a rich fuel mixture, i drove a car with the G.A.V. left open and after 1 mile the fumes would be strong enough to remind me to turn it closed again.
08-31-2012, 06:45 AM | #16 |
Re: Smell of Gas
I installed the cork gasket and it is fine now. No more gas smell.
08-31-2012, 07:39 AM | #17 |
Re: Smell of Gas
FYI - if you have a closed-car, and drive with the windshield swung all the way open (out over the filler cap), it is not unusual to catch a whiff of raw gasoline from the vents in the fuel filler cap, particularly in warm weather.
08-31-2012, 11:27 AM | #18 |
Re: Smell of Gas
It's never normal to get out and be light headed....
08-31-2012, 12:00 PM | #19 |
Re: Smell of Gas
Check the seal on the gas cap.
If you find a minor weap around the steering column mount on the gas tank, will the magic gas tank sealer work? I know the best solution is to remove and fix properly. As others have said, the gas gauge glass seal loves to leak. Sometimes it is hard to detect. CLean the instrument panel thoroughly and close up the car. Better if it is in a garage with still air. The next day enter the garage and follow your nose. Sometimes a white paper towel rubbed on the gas gauge glass will show pink even tho you can see the wet gas. I use Momma for specially hard gas smells. She still has a sharp nose for bad oders. My nose has been ruined by too much av gas and aroma monents. Clec |
08-31-2012, 12:02 PM | #20 |
Re: Smell of Gas
I felt light headed yesterday during a run with my 29 Packard. YA think it had to do with the womens chasing me???
