Old 04-13-2012, 05:48 PM   #1
30ratrodder
Default speed-o-meter gear
Hi All
I have a closed drive shaft for a 1940 rear-end. I'm looking to find a new gear for the speed-o-meter. I don't know how you would call it but it is for the little aluminum part that is on the tube.
Thanks
30ratrodder is offline   Reply With Quote
Old 04-13-2012, 05:56 PM   #2
super flat
super flat's Avatar
Default Re: speed-o-meter gear
speedometer drive unit. be aware there are different tooth counts for the tire sizes and gear ratio. Gary
super flat is offline   Reply With Quote
Old 04-13-2012, 05:58 PM   #3
Nirvana
what number do you have on the turtle now?
Nirvana is offline   Reply With Quote
Old 04-13-2012, 07:02 PM   #4
Bassman/NZ
Bassman/NZ's Avatar
It's called a turtle and with standard rear 3.78 gears it has 19 teeth. A 3.54 rear will have 18 teeth, 4.11 will have 21 teeth.
Bassman/NZ is offline   Reply With Quote
