01-29-2012, 09:40 AM | #1 |
what kind of clutch?
What kind of pressure plate and disk is this?
this is in a 37 21 stud mtor...Brendan
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
01-29-2012, 11:25 AM | #2 |
Re: what kind of clutch?
32 - 34 as a unit with the flywheel . The intake is 34 . ADDING Walt is right in the next post . In a march 34 parts book the pressure plate shows 1928-1934 , the disc shows as 1929 - 1934 & the flywheel is 32-34 . The entire unit is 32-34 but you did ask only about the disc & PP so my bad .
01-29-2012, 02:37 PM | #3 |
I think that's the same pressure plate as a Model A. 34 was the last year of this type. Walt
01-29-2012, 08:06 PM | #4 |
Same disc fits 29-46 ford-at least in Canada.Your engine also has the 33-36 dist.Quite common to find multi year parts on a given engine.
01-29-2012, 08:10 PM | #5 |
could you use the flywheel with a later cover plate?
01-29-2012, 11:36 PM | #6 |
01-30-2012, 12:31 AM | #7 |
No - unless you have it modified . the newer style cover plate bolts to the flywheel's face with 6 bolts spaced in pairs .
01-30-2012, 01:25 PM | #8 |
From my 34. How are things in Santa Rosa ? I used to live in Petaluma & then Valley Ford.
01-31-2012, 08:24 AM | #9 |
things are good, it cold in the morning then it worms up to about 63, we still are behind in rain
01-31-2012, 08:28 AM | #10 |
That is a early spring operated clutch outfit. Later clutches were combination spring and centrifical and in my opinion much better. The faster the engene went, the harder they held. A much smaller pressure plate could hold as much as a great big spring operated rig.
