Old 12-13-2011, 10:17 PM   #1
Tinker
Tinker's Avatar
Default Home made tools
Was looking around the two forums (hamb and barn) and see Vergil of the hamb posted this nifty little tool for tightening the belt.
Anybody else have some flathead homemade tools?
Old 12-13-2011, 10:44 PM   #2
Tim Ayers
Default Re: Home made tools
I like that. Yes: I made a clamp for getting the rod caps on with out dragging on the studs and a little do-hickey to that screws into the drain plug hole in trans case and allows you to mount it in a vise while working on it.
I'll post picts. later.
Tim Ayers is online now   Reply With Quote
Old 12-14-2011, 02:01 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I was always hoping a thread would start here on tools or gadgets that members have made to work on the early Fords. I have made a number of tools while working on my cars. Some of these tools could have been purchased but I enjoy designing and making tools when I have the time. I'll post pictures when I can get back to my computer.
OK, here are some of the tools I have made......I have more but can only post 15 pictures at one time here by this method.
John
Old 12-14-2011, 05:38 AM   #4
Rem
Rem's Avatar
Not really anything you can't buy, but I made my own early Ford spring spreader, that by using a combination of inserts, brackets and different length threaded sections, will do all the springs that I have needed to so far, including reversed eye ones. If I ever have to do a Model A spring I'll have to come up with a joggled centre piece, though
Rem is offline   Reply With Quote
Old 12-14-2011, 07:04 AM   #5
Hoop
Hoop's Avatar
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 12-14-2011, 07:48 AM   #6
PeteVS
PeteVS's Avatar
Two ways to hold a transmission (bed frame angle iron)--
Old 12-14-2011, 09:20 AM   #7
oldford2
oldford2's Avatar
The tool for tightening the belt is nice but only works on 8ba and later blocks. The wire looms are in the way for earlier engines.
John
oldford2 is offline   Reply With Quote
Old 12-14-2011, 10:18 AM   #8
ventilo
I guess you'll recon' this one
ventilo is offline   Reply With Quote
Old 12-14-2011, 11:27 AM   #9
PeteVS
PeteVS's Avatar
Originally Posted by al pa. View Post
I haven't been able to figure out the function of the tool,with the two C-clamps,but it appears to be very well put together.
For the screws that hold the detents on a floor shift trans top...
Old 12-14-2011, 11:35 AM   #10
FRANK PKNY
FRANK PKNY's Avatar
Tool for removing the oil pressure sender. Works great.
FRANK PKNY is offline   Reply With Quote
Old 12-14-2011, 12:40 PM   #11
JM 35 Sedan
Frank, I'm guessing that's a paperweight for the dollar bills you are making LOL!!
I know it is actually a neat tool made to remove an oil pressure sending unit that is screwed into the back of a block
Hoop, I give up What is your tool creation used for
Ah ha, now I know what it is based on the latest pictures you have added. That's slick!
Here are a few more pictures of tools I have made that could not be posted above.....
John
Old 12-14-2011, 01:41 PM   #12
Hoop
Hoop's Avatar
Old 12-14-2011, 02:37 PM   #13
JM 35 Sedan
I like that a lot better than a slide hammer tool that I made years ago to do the same thing.
John
Old 12-14-2011, 02:41 PM   #14
FRANK PKNY
FRANK PKNY's Avatar
About the dollar bill . I I learned many years ago that a bill is exactly six inches so when you take a photo for reference or need a quick ruler use a bill IE three bills equal 18" . Works great.
Old 12-14-2011, 02:54 PM   #15
Mart
Mart's Avatar
Nice tools guys, very ingenious.
Old 12-14-2011, 03:47 PM   #16
uncle max
uncle max's Avatar
Powervalve circuit blowerouter tool and hand-held spot facing tools for gasket surfaces on jet wells and fuel inlet.
Whoopee...
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 12-14-2011, 05:31 PM   #17
Lawrie
Lawrie's Avatar
distributor tester,tried for ages to buy an old ford one ,gave up and made one.
Lawrie
Old 12-14-2011, 06:10 PM   #18
flatjack9
flatjack9's Avatar
Now that is impressive.
Old 12-14-2011, 06:59 PM   #19
Hoop
Hoop's Avatar
"distributor tester,tried for ages to buy an old ford one ,gave up and made one.
Lawrie"
... or you could have done it the hard way.
Old 12-15-2011, 01:41 PM   #20
Junknshit
Banned
Some really good tools in here, some of which I can see that I am going to have a use for, hopefully in the near future. I do have a question about the one in post #9 by ventilo from Germany, what is it? Does it by chance have something to do with valves, or valve and guide assemblies? Or could it have something to do with straight axles? Or am I just so far off that I need to start at the very beginning again? Probably, Huh? I can see that the sleeves slide on and hold it together, or that it slides into the sleeves. I can't tell from the pic what size it is, although the rock looks like small peagravel to me.
After all, today is "Help a dummy day" isn't it?
Junknshit is offline   Reply With Quote
