Old 11-10-2011, 05:10 PM   #1
RPMREX
Default How does a '36 Cowl vent stay closed?
I bought my first 1936 Ford 3 window and the cowl vent won't stay closed. It operates fine but there isn't any catch to keep it completely down.
Wouldn't there be a latch type catch or something that the arm would catch on to keep it closed or open for that matter. It does stay open.
Any pictures would be Great!
Thanks!
RPMREX is offline   Reply With Quote
Old 11-10-2011, 05:17 PM   #2
Tinker
Tinker's Avatar
Default Re: How does a '36 Cowl vent stay closed?
Do you have one of these? Ratchet.
http://www.ebay.com/itm/1935-1936-Fo...item519751a1d4
Don't have any pictures. To dark outside for the camera already.
Old 11-10-2011, 05:42 PM   #3
RPMREX
Yep.
I just looked. When i pull the chrome bar toward the dash, it doesn't want to go far enough to let the ratchet bar notch to catch. The spring is hooked up and all seems to be working right but it wont quite go far enough to catch in the notch and the end of the slide.
When I was just looking at it and trying to push up the slide bar while pulling on the chrome bar so as to help the notch catch, the ratchet/slide bar came off the top attachment post. The ebay link that was sent shows a small spring, what is that for and where does it go?
Old 11-10-2011, 05:50 PM   #4
35 coupe
35 coupe's Avatar
I have a 35 coupe, and the small spring is a compression spring to put tension on the slide bar. you have a bolt with a large washer ( mine is brass) against the slot, the compession spring and another washer. you tihgten the bolt to contrrrrol tension on the slide, to keep it open or closed in different positions. Hoped this helpeed.
35 coupe is offline   Reply With Quote
Old 11-10-2011, 05:58 PM   #5
richbud37811
Theres a spring that goes from the bar its connest next to it to the curved bar used a brake spring on my car just didmine this moring.
richbud37811 is offline   Reply With Quote
Old 11-10-2011, 06:14 PM   #6
Gary Tosel
Gary Tosel's Avatar
I hope this picture will help. The brass washer for mine in on both sides of the slide arm with a thick washer below the nut that tightens the small spring.
Gary Tosel is offline   Reply With Quote
Old 11-10-2011, 07:04 PM   #7
RPMREX
Gary, that does help. Do you have a picture of the other side showing the little spring? Mine doesn't have a littlt spring. It looks like some one put in a solid steel tube.
Old 11-10-2011, 08:51 PM   #8
Gary Tosel
Gary Tosel's Avatar
Sorry the picture is blurry, but I think you can see how the spring works.
Old 11-10-2011, 09:31 PM   #9
Lawson Cox
Lawson Cox's Avatar
Some (most) vent gaskets are too thick, causing a problem similar to yours. The vent will not close all the way.
Old 11-10-2011, 11:09 PM   #10
RPMREX
Does anyone sell that spring and bolt setup?
What do I do about the gasket being to thick? I was assuming that was the problem.
Old 11-11-2011, 07:42 AM   #11
jim1932
jim1932's Avatar
The starting place for me for most bolts like this is Roy Nacewitz fordbolts.com
jim1932 is offline   Reply With Quote
Old 11-11-2011, 08:33 AM   #12
Terry,OH
Terry,OH's Avatar
As you can see in Gary Tosel's photo the stud with the spring is part of the arm and not easily removable. If yours is missing (broken off) this stud that the spring fits onto you could replace it with a 1/4-28 bolt without a hex head. It will have to be welded or peened in place ( due to clearance)and it should have a hole in the end for the cotter pin for the nut on the end. there are two brass washers on the stud, steel washer, roller, spring, and the slotted hex nut. Even if the gasket for the door is too thick and you replace it the door will not close properly without the stud and hardware and it has to be in the exact location as the original.
Old 11-11-2011, 06:12 PM   #13
RPMREX
I checked fordbolts.com they sell the castle nut and cotter pin but not the cowl vent pivot stud.
Does anyone know where I can get the cowl vent pivot stud and spring, washers, nut ,cotter pin etc as a kit or individually for that matter?
Old 11-11-2011, 07:51 PM   #14
41panelmark
41panelmark's Avatar
I have the same problem with my 41, any ideas on what to do to make it close down tight?
41panelmark is offline   Reply With Quote
Old 11-13-2011, 01:38 AM   #15
nitrohonkey
nitrohonkey's Avatar
On my 36, it is frozen shut with rust...any ideas on how to open it without doing damage to any of the components?
nitrohonkey is offline   Reply With Quote
