10-18-2011, 04:24 PM | #1 |
400A body manufacturer
I've learned on here that all known Victoria bodies were produced by Murray.
Over the weekend a friend with a 400A asked if I knew whether his car had a Briggs or Murray body. Any help? Thanks. |
10-18-2011, 04:57 PM | #2 |
Re: 400A body manufacturer
Murray ,, and i am glad you said 400A [NOT A400 ] .
10-18-2011, 06:54 PM | #3 |
Pete's right. All Murray. Should have a Murray body tag on the firewall. Also a give away are the square clinch nuts used only on Murrays. For example the two under the hood down at the bottom of the steering column where the peddle pad screws on from inside the car. On a side note, I think A-400 sounds nicer off the tonge
DMAFC |
10-18-2011, 07:35 PM | #4 |
400-A sounds Canadian...............not that there is anything wrong with that.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
10-18-2011, 08:12 PM | #5 |
What is your friends name?
Is he a member of the A400A Group? Have him contact me [email protected] Thanks Joop PS. Arlen gave the right answer No Briggs bodys only Murray .. Last edited by Joop; 10-18-2011 at 08:44 PM. |
10-19-2011, 02:34 AM | #6 |
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
10-19-2011, 06:24 AM | #7 |
I want to go on a limb but think that all of them were screwed on
It are the aftermarket tags that are mostly attached with rivets. .. |
10-19-2011, 04:10 PM | #8 |
My observations have been the opposite to yours, pretty much 100% on Victorias. Because both bodies were built by Murray and they share a number of body parts I assumed that the practice of attaching body tags would be the same. My 190-43230 was screwed on.
