Old 09-12-2023, 12:48 PM   #21
Model "A" Fords
Default Re: Canadian rad emblem is different than U.S.A.
Originally Posted by Model "A" Fords View Post
At work I have a photograph of a very early shell. An interesting piece for sure. Bob Intini
I have added the photograph of a very early rad shell owned by a friend and Model A Judge. The tooling for this, was probably sent to Canada in 1927 by Ford U.S.A.. Canada started production of the Model A in 1928 and tended to lag American time lines to various degrees. They also made changes to parts to keep me busy researching!
The shell tooling could have been used in U.S.A. first then sent to us or made specifically for Canada. Still researching.
You can see the two slots in the shell that correspond to the two tabs on the back of the emblem. The owner has seen one of these shells complete with a Canadian emblem mounted on it but not any U.S. as of yet.
If you have any information or photographs on this early piece, please post here.
Model "A" Fords is offline   Reply With Quote
Old 09-12-2023, 05:32 PM   #22
Bick in New Zealand
Bick in New Zealand's Avatar
The U.S. supplied shells, that required the lacing threaded, also had the two locating slots for the emblem. It would appear that there were two versions of the threaded shells. One with large holes for threading, and then an interim version, that had both large holes for threading, and also smaller holes for riveting. My Canadian version also has a number stamped on the edge, as per photo. Has anyone else noted this feature, I am wondering if these Canadian shells were sequentially stamped?
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 09-12-2023, 05:39 PM   #23
Bick in New Zealand
Here is an interesting photo, of an early shell posted by John LaVoy. It is probably not Canadian, but worth posting. It shows that the shell was stamped originally like the Model Ts, before being stamped to accept the separate emblem.
1931 Victoria RHD
Old 09-12-2023, 09:59 PM   #24
Model "A" Fords
Bick, can you show us the emblem area, front and back?
Is there any front photograph that you know of? Are you thinking it was U.S. or somewhere else? Do you know if a Model A ever used the shell with just the Ford script in the oval stamped directly in the piece as it looks like the hole in this one was an afterthought?
Old 03-30-2024, 07:14 AM   #25
rackops
rackops's Avatar
Sorry for being late to this thread about the radiator shell. I was looking for info on the badge and saw the subsequent posts. I had a VE28 shell at one point and it also had the tabs for the badge. It was US-made (I assume) and there were no numbers on it anywhere.
Member, MAFCA and MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" and a 1931 Victoria "Katie"
Former owner, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 03-30-2024, 04:44 PM   #26
updraught
updraught's Avatar
https://www.fordbarn.com/forum/showp...60&postcount=2
updraught is offline   Reply With Quote
