02-14-2024, 05:27 PM | #1 |
What are these holes under dash for?
Driver side, under starter button. They look factory (and very much like the holes for the dimmer switch on the other side of the column). I might use one of the holes for something else but want to make sure they are not for something else first. Thanks!
5B732A76-3D38-4207-8909-969F5B71535A.jpg 8B54FDFE-BC5E-4916-8A2F-2627E0EC6838.jpg.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
02-14-2024, 05:32 PM | #2 | |
Re: What are these holes under dash for?
02-14-2024, 07:00 PM | #3 | |
02-14-2024, 07:12 PM | #4 |
Thanks Kube.
02-14-2024, 08:02 PM | #5 |
Isn’t that where the super deluxe trip odometer was ?
02-14-2024, 08:13 PM | #6 |
02-15-2024, 05:39 AM | #7 |
Sorry, mixing 41 term . Where does the trip odometer set button go on a Deluxe 40 ? Sorry for the hijacking .
02-15-2024, 06:31 AM | #8 |
try dash dimmer and heater fan switch thats where mine are there should be same on otherside so right and left drive taken care of in one production piece
02-15-2024, 08:03 AM | #9 |
02-15-2024, 08:27 AM | #10 | |
Right vs. left hand drive instrument panels are distinct stampings.
02-15-2024, 02:03 PM | #11 |
02-15-2024, 03:29 PM | #12 |
Not sure this will help but, the dash on my 40 DeLuxe coupe looks like this.
All holes in the dash are OEM. I have not added any holes but did use a few of the stock holes for an ignition kill toggle switch and installing a 12V push button starter switch under the dash so as to bypass the OEM starter button. The stock starter button isn't connected. The last photo shows the instrument panel dash light dimmer switch almost behind the steering wheel lock. Last edited by 19Fordy; 02-15-2024 at 03:39 PM. |
02-15-2024, 03:48 PM | #13 | |
02-15-2024, 05:06 PM | #14 |
Thanks, Mike, for that info. I checked your book and on page 5-17, there it is.
When I bought my 40 in 1963, the heater switch was on the left of the dash. I guess it was moved for some reason. Although, it makes sense that the heater switch would be on the right, closer to the heater. 1st photo shows where it's located now. Should it be located where the toggle switch for my fuel pump is now located in 2nd photo - to the right of the dash light dimmer switch.? There was already a hole there so I used it for my fuel pump on/off toggle switch. |
02-15-2024, 08:05 PM | #15 | |
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 02-15-2024 at 08:09 PM. Reason: added photograph |
02-15-2024, 09:45 PM | #16 |
Thanks Kube for the reply. I will heed you advice as my car is not stock.
