02-10-2024, 05:40 PM | #1 |
8BA Fan hub information needed
Would anyone know what year this Ford flathead fan hub assembly is from?
The one pictured is the last one I have I'm looking for another but have no idea what year or vehicle it was used on. The three blade fan is riveted to the metal flange and it has a narrow belt pulley. I like this type over the cast iron version that has a bolt on four blade fan hub and the pulley all cast as one part. I have a few of the cast type but they wont work for my latest project. Any help would be greatly appreciated. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 02-10-2024 at 05:48 PM. |
02-10-2024, 06:21 PM | #2 |
Re: 8BA Fan hub information needed
Found this pic in one of my albums. Not sure if it is exactly what you are looking for as it seems the belt is wide, but when I Google that P/N (8600), this thread popped up. Still no answer as to year, but someone here will surely chime it.
https://www.fordbarn.com/forum/showthread.php?t=271273 |
02-10-2024, 07:03 PM | #3 |
The wide belt fan assembly was used in the 1948 to 1953 trucks. The thin belt fan assembly was used in the passenger vehicles from 1949 to 1953.
02-10-2024, 07:04 PM | #4 |
The four blade wide belt fan is '49 only. The three blade narrow belt fan is '50-'51. I am not sure if it continued unchanged to '52-'53.
02-10-2024, 07:09 PM | #5 |
Found this fan assy like yours on eBay (UK), it has what looks like P/N on the back in the last pic.
https://www.ebay.co.uk/itm/154674191668 |
02-10-2024, 07:29 PM | #6 | |
02-13-2024, 07:47 PM | #7 |
I have one taking up space in the garage if you are still in need.
02-13-2024, 08:10 PM | #8 | |
02-14-2024, 08:54 AM | #9 |
My brothers 53 custom has that same fan assembly on its EAB V8. I always wonder what a guy should do when the bearing starts making noise. Tim
02-14-2024, 09:32 AM | #10 |
Replace it. It is a common water pump bearing (NSK 885586) that should be readily available (at least they were a few years ago). The shaft has to be shortened and it is best if you have a press, although I did it once with a big vise.
02-15-2024, 05:51 PM | #11 | |
I have some room left in my garage sent you a PM
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
