01-16-2024, 08:51 AM | #1 |
Overheating Flathead
Just a thought has anyone ever tried the cooling trick Barney Navarro used. Placing a length of copper pipe behind the water pump cavity through the water jackets to the back of the block to increase cooling and circulation.. Anyone try this . Let me know if its worthwhile to try.
Thanks |
01-16-2024, 08:55 AM | #2 |
Re: Overheating Flathead
I would like to see how that is done. Have heard of it but believe there is more to it than just putting a tube in the block.
01-16-2024, 09:21 AM | #3 |
That's why the coolant holes in the head gaskets get larger as they go toward the back of the engine. Dodge and Plymouth had a brass tube that went from the water pump to the back of the block that distributed coolant at each exhaust valve seat . Kind of the same concept , cooling evenly for the entire length of the block. Tim
01-16-2024, 01:03 PM | #4 |
Besides Chrysler Products all big block MELs have 3 thermostats and two 'of those' water divertors...Mercury Edsel Lincoln............
01-16-2024, 02:18 PM | #5 |
That's something i did on one of my all our race flatheads. The idea is simple get more coolant to the rear of the block all I can say is it wont hurt a bit.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-16-2024, 03:03 PM | #6 |
01-16-2024, 05:32 PM | #7 | |
It is not so much the rust in the water jackets that causes heating problems as it is the scale and stripping is the only thing that will get all of the scale out. |
