Old 11-22-2023, 04:30 AM   #1
Bruce of MN
Bruce of MN's Avatar
Default Manifold Heater
I saw this photo on another forum. What is that trumpet behind the carb? Some sort of fresh air inlet?
Old 11-22-2023, 07:28 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Manifold Heater
Must have been for really cold climates. The funnel directs air to around the exhaust pipe to add to the air going across the exhaust manifold. I like the removable patch near the distributor which I assume is to gain access to the screw hold the distributor in place.
There is a lot more going on in this photo. What is the funny thing where the sediment bowl would normally be? Also, what is the black object on the port side of the car?
Old 11-22-2023, 07:54 AM   #3
Brian SATX
Brian SATX's Avatar
It is a late firewall and indented. That is the fuel shut off. The sediment bowl is supposed to be attached to the carb, but different that the early one.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 11-22-2023, 07:59 AM   #4
Big hammer
Sediment bowl is on the carb agree about the electric fuel valve, the black object could be an electric motor for the horn hanging under the hood middle
get a bigger hammer tap done
Old 11-23-2023, 11:00 AM   #5
Bruce of MN
I got the pic from the HAMB, but can't find the thread now. The black box does connect to the horns.
Old 11-23-2023, 01:10 PM   #6
1930artdeco
1930artdeco's Avatar
That little tube behind the carb is for heating the carb in cold climates. I have that same manifold but never used the carb heater. Why they have the funnel and tube I don't know as it won't do anything to heat the car up.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-23-2023, 03:22 PM   #7
Gene F
Gene F's Avatar
I have driven my A in the winter, and never noticed any thing with the carb other than opening up the fuel mixture till it gets good and warmed up.
Old 11-25-2023, 12:30 PM   #8
Gary WA
Gary WA's Avatar
Unauthorized accessories book.
www.whidbeymodelaclub.com
Old 11-25-2023, 01:19 PM   #9
700rpm
700rpm's Avatar
What is the cream yellow material between the manifold heater and the firewall door?
Ray Horton, Portland, OR
Old 11-29-2023, 08:23 AM   #10
8EL
Looks like a solenoid valve, is probably energized with the key, to automatically shut the fuel off with the engine.
8EL is offline   Reply With Quote
