10-09-2023, 06:14 PM | #1 |
Water pump rebuild kit? Where to buy.
My water pump is leaking at the packing seal It looks like the bushings are shot too. The car came with a used spare water pump, but the bushings are worn out on this one as well. Is it worth while to rebuild these water pumps? I couldn't find any rebuild parts, just new pumps on Snyder's and Lang's.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
10-09-2023, 07:04 PM | #2 |
Re: Water pump rebuild kit? Where to buy.
Stop in at a good machine shop, they can make bushings if they are not a standard size. Model A Ford packing might work to seal it up.
10-10-2023, 02:44 PM | #3 |
Waterpumps were basically an accessory. ModelTs would thermosyphon pretty well as long as the radiator tubes and water jackets in the engine are clear of obstruction. A lot of the accessory stuff was aftermarket.
Ford only put pumps on the very early cars and likely only around 200 cars were so equipped. |
10-10-2023, 06:55 PM | #4 |
Even tho most were not equipped with a water pump, many were sold aftermarket. I put one on my car just because I thought it looked good.
10-10-2023, 08:02 PM | #5 |
I coughed up the money and ordered a new water pump. The two old ones I have were different brands and I might think about rebuilding them at a later time to keep as spares. I just wanted to make my T roadworthy so I can get used to driving it. I live in the foothills, so I'm not sure if thermosyphoning can be relied on.
10-11-2023, 10:32 AM | #6 |
10-11-2023, 03:23 PM | #7 |
My Mother's family spent summers on the west slope of Mount Blanca in the east edge of the Sangra De Christo range of Colorado. All they had for long distance travel was a model T touring car. She said that there were a few slopes they had to negotiate in reverse but the old T could make it up most hills in low. The Levita pass was a slow drive up and a scary ride back down but the old T made it. They carried water bags to replenish lost coolant but they only stopped if it started blowing steam.
They did the trip from southwestern Kansas and back for a number of years till the depression finally put a stop to it. The old Ts did OK with no waterpump. If a person has a speedster with healthy modifications then a coolant pump and better brakes would be in order. |
10-11-2023, 06:18 PM | #8 |
I was worried when I first bought the T if it could handle going up and down my driveway. It's over 1/2 mile long and a 16% to 20% grade with three switchbacks. A total change of elevation of 320 vertical feet. It did o.k. though, I just retarded the timing going down with my hand on the brake lever. Going up I used pedal down and Ruckstell low. I also tried going up with the Ruckstell in high, but I had the throttle it up to keep from stalling and it was a little too scary on the turns for my liking. I thought it might overheat, but no steam. I'm not sure how it would do with my wife and two kids in the car. I might test the waters before I attempt the descent with a loaded car. My AA does just fine going up in second gear, no effort.
10-19-2023, 12:20 AM | #9 |
Sounds like a good set of outside brakes might be a good idea given the description of your driveway.
10-19-2023, 03:32 PM | #10 |
Bushings and stainless steel shaft can be gotten from MacMaster Carr. You will need to work out what sizes you need to order.
I know the voices aren't real but damn they have some good ideas! |
