09-27-2023, 11:53 AM | #1 |
Stripped oil pan nut
The far rear but on my oil pan seems to be stripped. Back by the starter. Can I make this oversize with the pan on? What is the next size up? Photo below.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
09-27-2023, 11:55 AM | #2 |
Re: Stripped oil pan nut
Use a thread repair insert.
09-27-2023, 01:46 PM | #3 |
Repair it the easy way. Different sizes are available.
09-27-2023, 01:51 PM | #4 |
are you sure that the front and rear two aren't larger than the others.
09-27-2023, 01:53 PM | #5 |
Not sure. I wondered this too. But all of the other ones torqued just fine. I could t even get this one snug.
09-27-2023, 03:58 PM | #6 |
Drill and tap new threads. Be sure to get the location correct. I just looked at a spare, to hard to put a nut inside. And I hesitate to go oversize. Karl |
09-27-2023, 05:23 PM | #7 |
Possibly take out the starter and use longer bolt and a nut
09-27-2023, 05:24 PM | #8 |
Helicoil
09-27-2023, 06:49 PM | #9 |
Ok so I ran a tap through it (original size) and then I was able to torque it. Not sure it will hold but we’ll see. Normally I’d take the pan off and tap it correctly, but I already took the pan off once for another screw up and dont want to do it again unless I absolutely have to…which I’m sure at some point I’ll need to do at that point I’ll repair correctly next time it’s off. The first time I torqued the pan down it torqued down fine so this is somewhat strange. I tried two different bolts that wouldn’t torque until I ran the tap through.
