08-29-2023, 11:49 AM | #1 |
Wire Harness
I’ve a 1941 Ford 1/2 Pickup and would greatly appreciate consensus on which vendor you recommend to explore purchasing a complete wiring harness to replace existing. After 80 plus years, it’s time. The electrical system has been converted to 12 volt system otherwise I believe it to be original. Sincerely appreciate your recommendation.
Thank you! Frank W Jonex |
08-29-2023, 12:39 PM | #2 |
Re: Wire Harness
Bauer Electronics
Chris Olsen 541-389-7755 |
08-29-2023, 01:33 PM | #3 |
Re: Wire Harness
Rhode Island wiring (401) 789-1955 IF you are wanting concourse correct.
08-29-2023, 01:43 PM | #4 |
Re: Wire Harness
If you don't care about looks get a hot rod EZ harness, all wires are marked and turn signals included.
41 woodie https://41fordwoodie.weebly.com/ |
08-29-2023, 01:53 PM | #5 |
Re: Wire Harness
YnZ's Yesterday's Parts
Wiring Harness Catalogs | YnZ's Yesterday's Parts (ynzyesterdaysparts.com) Top notch and they can customize it according to your needs such as turn signals.
08-29-2023, 02:53 PM | #6 |
Re: Wire Harness
08-29-2023, 04:32 PM | #7 | |
Re: Wire Harness
08-29-2023, 05:03 PM | #8 |
Re: Wire Harness
My vote also for Bauer like ssffnomad. Chris will make it any way you want, Dearborn correct, turn signals added, or custom like on my 32 5w, running a 59 series engine and put a Vreg on the passenger side of the firewall. I have 2 40s, and a 32 5w with Chris's harnesses, everything fit, 2 Dearborns with the my 40 wagon. Never a problem. He is also not that far from me and is very prompt about shipping stuff out.
08-30-2023, 12:51 PM | #9 |
Re: Wire Harness
Thank you so very much for all of your input. Great info that I’ll use to make a selection.
The info you provide is of value to us newbies. Frank W Jones 41 Ford 1/2 Ton Pickup |
08-30-2023, 03:13 PM | #10 |
MEMBER EMERITUS
Re: Wire Harness
Tyree Harris.
