08-22-2023, 08:06 PM | #1 |
Wheel Restoration
I get a lot of info about my 36 Club Cab but this is off the mark. I have a 1956 Bel Air and am looking to get the riveted two piece wheels restored. Can anyone recommend somebody
08-22-2023, 08:16 PM | #2 |
Re: Wheel Restoration
Are they badly pitted? Are the rivets loose ? If not, try a local body shop where they can be sand blasted and repainted. Also google wheel repair in your area
08-22-2023, 08:26 PM | #3 |
My answer was about the same as pauls, so I deleted it.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
08-22-2023, 08:28 PM | #4 |
Or.......look for a cemetary monument business -- they usually sandblast wheel rims.
08-22-2023, 09:20 PM | #5 |
08-22-2023, 09:36 PM | #6 |
08-23-2023, 06:02 AM | #7 |
My problem is: i have reproduction wheels on the car now and two are leaking at the rivets. One is much worse than the other 7-8 lbs. a day. Hubcaps are spinning and bending over the valve stems. I was told to find original wheels and caps, and have them restored. Hubcaps are not a problem getting done but can't find anybody for the wheels to take them apart and restore
08-23-2023, 11:24 AM | #8 |
I would not take the repro. "leaky" wheels apart if they are now "on center" and running true.
To stop the leaks use a very stiff wire wheel to clean up the rivets and surrounding area. Then apply JB Weld or another good epoxy over the rivets and surrounding area. or If you have a TIG or MIG welder, weld the rivet head to the inside of the rim to seal the leak. Finish the weld nice and smooth so wheel can be balanced with minimum amount of weights. Last edited by 19Fordy; 08-23-2023 at 11:46 AM. |
08-23-2023, 09:26 PM | #9 |
Unless your doing a high points restoration why not contact a reputable company like Wheel Smith to make you some stock style wheels and order them powder coated in your color choice.
08-23-2023, 09:46 PM | #10 | |
One thought: If your wheels accept tubes, that will solve the immediate problem of leakage. |
08-23-2023, 11:39 PM | #11 |
I'm a fan of real paint, not powder coat. I used to do it all at home, have the big portable compressor ( think jack hammer) , and could buy silica sand rite out of the mine 30 miles away from me at 1 1/10 of the price of buying bags at the lumber yard. The old bag that
ran the office always argued that we don't sell by the pallet load, only big truck loads. I would show her the papers that showed I payed a deposit on their pallet, which I have in my truck, it was always a fight, which I always won, until I didn't. Now, to buy sand at the lumber yard, and F around getting the compressor running that hasn't been run in years, and buy gas, its become the habit to hire it done. Option 1, a local guy, a friend really, is so cheap I can't do myself. Problem is, he blasts snow plows and dump truck boxes etc, so "light brown" is good enough, and it would seem he uses 3/4" rock for blast material, the stuff is beat to hell when I want to paint it. Option 2 is a guy that does car parts. He cost more, but things come back spotless clean, and smooth enough to prime. absolutely not a brown speck anywhere, ready to prep for paint. Years ago when I worked for company that had a truck fleet I used their powder coat company for my pickup wheels. My precious 89 dodge diesel never gets driven in salt, and the cheap powder coat lasted about 2 years. Now look like a rattle can job. Now... I have my good blaster guy clean em up, and I paint with epoxy primer, and acrylic urethane paint, done on my wheel painting machine. This was made for wheels, but I have since made many adaptors to do other parts. Even a rack to spin gas tanks for cleaning. It runs at 5 RPM, and you can practically pour the paint on, no skill required, it flows out perfect every time. Sorry for another long late night rant... |
08-24-2023, 12:48 AM | #12 | |
NICE!
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-24-2023 at 12:57 AM. |
08-24-2023, 06:02 AM | #13 |
Thanks. Beautiful set up
08-24-2023, 08:03 AM | #14 |
Pretty slick idea. Nice job.
What kind of gear reduction device did you use to obtain the 5 RPM? |
08-24-2023, 10:39 AM | #15 |
I don't see a tag on the gear reduction box, but I think its 100 to 1, then the big pulley is about 14". If it ran slightly slower it would be better.
08-24-2023, 03:41 PM | #16 |
Bob if the rivets are leaking they are working, meaning they are loose and they will eventually come apart. get rid of them and don't sell them to any body. I would call the manufacture and let them know your situation. Find a good set of stock wheels with little or no rust and have them media blasted and painted to your specifications. JMHO !!!!
