09-30-2015, 02:15 PM | #1 |
A Frame dimensions
Could use some help. wescottsauto.com lists 103.5" wheel base, but if you add all there dimensions it comes up a 1/4" short. the running board mounts from center of rear cross member to center of drivers rear running board bracket is 22 1/2 " 29 Ford chassis lists it at 29" and 27 3/4" to front drivers bracket. Wescott has no dimension for front bracket. I have spent hours looking for the correct dimensions to still have doubt what is right. I purchased Model A plans from an outfit in Canada and they are hot rod plans without any original dimensions for me it was a waste of money.
Thank you for you time. If mounting hole dimensions are correct please let me know. Terry |
09-30-2015, 03:37 PM | #2 |
Re: A Frame dimensions
I believe the frame dimensions are also in the Judge Standards.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-30-2015, 04:48 PM | #3 |
I looked in the RG&JS and there are no frame dimensions.
Here is a link to a site with the frame dimensions http://1929fordhotrod.com/johnsblog/...me-dimensions/ Attached is the photo from the above link.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-30-2015, 04:51 PM | #4 |
The dimensions are also at: wescottsauto.com
Charlie Stephens |
09-30-2015, 05:05 PM | #5 |
Here is a link to Westcott site with the frame dimensions.
http://www.wescottsauto.com/WebCatal...ram1928-31.pdf Attached is the jpg from the above link.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 09-30-2015 at 05:10 PM. |
09-30-2015, 06:13 PM | #6 |
09-30-2015, 08:51 PM | #7 |
Found this floating around. Don't know the source. See if it adds up. Good luck.
10-01-2015, 10:41 AM | #8 |
Wescott's drawing shows from centre of front cross member to centre of rear cross member as being the same as the wheel base. This is wrong because of the camber of the front axle. The wheelbase is actually longer than the crossmembers C to C.
Ken in Alberta
10-01-2015, 01:09 PM | #9 |
Katy, add all the numbers from front center line to rear center line there's 1/4" short. Which of the measurements is off?
10-01-2015, 03:09 PM | #10 |
Here is the chassis diagram from "How to Restore the Model A Ford" from Clymer Publications. This might clarify, or throw fuel on the fire.
I will attempt to re-check all measurements against original frames this winter and revise the drawing as needed. Karl Wescott |
03-28-2020, 10:29 AM | #11 |
also some of the body mount brackets and running board stuff is off.
04-03-2020, 01:26 PM | #12 |
Welcome to Aftermarket Parts. Good enough seems to the the norm. Ugh!! 1/4" is the max for spec on a frame. But "0" is better.
08-28-2022, 07:11 PM | #13 |
Pretty sure I saw a Model A factory drawing with a scale " plus or minus 1 inch"
08-29-2022, 06:23 AM | #14 | |
