06-30-2022, 10:45 PM | #21 |
Re: need a new 6 volt battery for my 1933
Which is the technology that Optima uses.
06-30-2022, 10:52 PM | #22 |
What Coop said. They are glass matt (fiberglass) batteries. No acid or lead levels to worry about. Closed cell. Why you can install them upside down. Yes you can just charge them like a regular battery. Use the maintenance free setting. On newer chargers there are settings for other types of solid state gel batteries. Know what condition your condition is in.
The acronym "AGM" stands for "Absorbed Glass Mat," which in the case of a lead-acid battery, means the electrolyte in the battery is absorbed into fiberglass matting in between the plates in the cells. All OPTIMA batteries are AGM batteries, but no OPTIMA batteries are gel batteries. Batteries and companies change over time. But Optima is/was AMG batteries. Last edited by Tinker; 06-30-2022 at 11:02 PM. |
07-01-2022, 10:03 AM | #23 |
The Optima websites indicates they are still making them. https://www.optimabatteries.com/experience/blog/6-volt/
07-01-2022, 12:47 PM | #24 | |
I had an old ford script lead acid battery that last 1 year. I hollowed out the case to fit my optima battery inside. I remember paying 150, for the optima. Today it is $240. Does Battery Central offer a 3 or 4 year guarrantee. |
07-01-2022, 01:07 PM | #25 |
Yeah, the Optimas have gone up in price and down in quality over the years.
07-01-2022, 02:12 PM | #26 |
However, I'm hoping to get 10+ years from it. Read post #6 above. Hopefully this Absorbed Glass Mat battery will last as long as an Optima. We shall see. That is, if I'm still around in ten years. |
07-01-2022, 02:26 PM | #27 | |
07-01-2022, 02:44 PM | #28 |
battery central classic is a great looking battery, no doubt. I am tempted to buy one myself, but I already have to shell from the junk lead acid script battery I bought when I first got my car.....The optima fits inside and the battery top holds the optima in place. I remember the chore I had grinding the inside of the rubber case to fit the optima in. Never do that again.
07-01-2022, 02:46 PM | #29 |
I guess that is better than discontinued. But it's not like a battery is something you can wait around months for if yours is bad and needs a replacement.
07-01-2022, 04:40 PM | #30 |
eventually, we all may have to convert to 12 volts because 6 volt batteries will no longer be available
07-01-2022, 05:27 PM | #31 |
I've got an Optima 6v dated 2014 that reads 6.8v on my HF digital charger/ maintainer ($26) and the battery cranks just fine.
I also have a 2016 date Optima 6v that reads 6.8, no issues. I leave it on a week and then skip 3 weeks. The Optima is one tough battery. |
07-01-2022, 06:40 PM | #32 | |
Frank....WATCH his lips! 6v batteries are about to be the least of your worries when there is no more gasoline. Coop . |
07-04-2022, 08:40 AM | #33 |
I put the optima battery I was having trouble charging in the freezer overnight.
Then I put it back on my smart charger and it charged up to full! WE used to do this at GE aerospace division to extend the life of NiCad spacecraft batteries. Last edited by FrankWest; 07-04-2022 at 09:09 AM. |
07-04-2022, 11:01 AM | #34 |
I totally agree johnson controls and east penn where some of the best battery builders around in my model a and 50 i always went to my local fleet farm stores since the local farmers still had plenty of 6 volt tractors you could pretty much be guaranteed a fresh one
07-04-2022, 11:57 AM | #35 |
I buy the NAPA Group 1 or Group 2 battery depending on the car. During the winter I hook up my 6 amp charger on each car about once a month until the charger shows that the battery is fully charged. That usually takes only 3 or 4 hours. I get anywhere from 7 to 10 years from each battery. I also have master disconnects to make sure there’s no drain. Nothing fancy but it’s worked for me for 20 years or so.
07-04-2022, 11:57 AM | #36 |
If you're willing to run a flooded lead-acid battery, you might check out Batteries Plus. I have been using their 6Volt batteries for my flatheads for the last 9 years - without any issues. They are only about $100 or so and have worked well for me (high horsepower flathead that I crank a lot to get fuel into the engine before I hit the 'mag' switch).
I keep mine on a battery tender - always works just perfectly and shows about 6.5 or so volts when coming off the charger. |
07-05-2022, 12:47 AM | #37 | |
Little something... why should anyone care about a country somewhere that's not here. Why? Maybe left unchecked you might be an island and powerless. American power is not determent by some guy in iowa with a thought or flag. It's global and backed by a lot of guys in iowa or where ever. Put yourself on the opitma 6v list and if you get one. Great! Last edited by Tinker; 07-05-2022 at 01:41 AM. |
07-05-2022, 07:48 AM | #38 |
So true..We will all have stationary museum pieces. I met a guy the other day that had a large pickup truck all-electric powered. I don't think he ever considered how he will get the energy to charge his massive batteries....
07-05-2022, 10:09 AM | #39 | |
Also, with the development of battery technology, they'll probably be able to come up with a superior substitute to what we have now. |
07-05-2022, 11:09 AM | #40 | ||
I heat my home with oil. hope that comes down before the fall otherwise it cost a fortune to heat my home. Last edited by FrankWest; 07-05-2022 at 11:41 AM. |
