07-01-2022, 11:32 AM | #1 |
Engine not turning, looks clean
I started to work on the family Model A that has been sitting in the garage for 15-20 years. I tried to turn the motor by hand with it in neutral, starter off, spark plugs off but no luck. When I dropped the pan, the motor looks SUPER clean. I don’t know what would be most likely reason for it not turning.
07-01-2022, 11:40 AM | #2 |
Re: Engine not turning, looks clean
Put in gear and try rocking forward? or reverse?
www.whidbeymodelaclub.com |
07-01-2022, 12:20 PM | #3 |
That was going to be my next step. Right after posting, I went out on my lunch break pried on the flywheel and saw a little movement from the fan! It’s still a bit hard to turn by hand, but I think sitting with MMO for another 24 hours will make it a little easier.
Anyone else ever asked for help, only to try to reproduce the problem with Help watching and everything works? I feel like that was me just now! |
07-01-2022, 12:39 PM | #4 |
Let it sit with the MMO in the cylinders for as long as you can. The rings are probably 'stuck' to the walls and pistons.
07-01-2022, 02:04 PM | #5 |
With the spark plugs out, try squirting oil in the cylinders.
This is a video worth watching: https://youtu.be/wGY0t4Qu-iM |
07-01-2022, 02:46 PM | #6 | |
Hasn't that already been done ? The MMO has been in for awhile. |
07-01-2022, 04:06 PM | #7 |
Remove the distributor and put some MMO or light oil down the hole there, it will get to the bearings.
07-01-2022, 04:48 PM | #8 |
I agree with J Franklin, REMOVE the distributor. An upper frozen bushing will prevent you from turning over engine.
07-01-2022, 06:12 PM | #9 |
07-01-2022, 08:23 PM | #10 |
Most likely Patrick is right (post # 4), the rings and pistons are stuck. Use a bore scope or a strong light to inspect the cylinder walls for rust. If there is rust your best bet is to take the engine apart. Start with removing the head.
07-02-2022, 04:44 PM | #11 | |
