02-15-2022, 04:57 PM | #21 |
Re: Iron OHV prototype
Getting there!
02-15-2022, 05:09 PM | #22 |
Looks good.
Thanks, jim |
02-15-2022, 06:08 PM | #23 |
Tod, glad to see your progress on the OHV. How can I get one?
02-15-2022, 08:13 PM | #24 |
What a beauty!
02-15-2022, 08:16 PM | #25 |
02-16-2022, 02:31 AM | #26 |
02-16-2022, 06:35 AM | #27 |
OK, the first fire up of the engine has taken place. I will post a video on Youtube, or you can view it on my Facebook page if you are on there.
EDIT: Here is the Youtube video link - https://youtu.be/X2zV8-KiBSU Tod Last edited by Tod; 02-16-2022 at 06:53 AM. |
02-16-2022, 08:54 AM | #28 |
Dang, that is cool!
02-16-2022, 09:17 AM | #29 |
That's impressive!!
02-16-2022, 05:42 PM | #30 |
I didn't realize that it used the stock manifolds.
Also, is the rocker cover adapted from another engine? |
02-17-2022, 06:47 PM | #31 |
3 sample rocker covers for the OHV heads just out of the sand before clean up and shot blast.
Tod |
02-17-2022, 07:17 PM | #32 |
Sounds like vintage sports car when you rev it.
02-21-2022, 09:32 AM | #33 |
Fine job, a great deal of thought has gone into this, and the results arequite rewarding. So far I've spent 2 years and a few mistakes in developing my new intake port. It's basicaly done now, time to convert a block and try it. Unfortunately, even if it works, it's not for street, racing only. However if installed in a new casting would increase to preformance of the stock engine.
I hope. Grampsr |
02-21-2022, 10:46 AM | #34 |
Ron,
maybe something like this?
As Carroll Smith wrote; All Failures are Human in Origin. |
02-21-2022, 02:27 PM | #35 | |
Thanks Ron. I'm looking forward to seeing your results. Tod |
02-23-2022, 05:31 AM | #36 |
"Aluminum is lighter and easier to port and modify. However aluminum can "suck" more heat out of the chamber due to it's higher thermal conductivity. The aluminum head may run cooler, which helps pack more air into the chamber because the incoming cool air does not pick up as much heat. Both of these aspects can help avoid detonation and improve volumetric efficiency.
However, loosing heat to the coolant rather than keeping in the chamber to push on the top of the piston should reduce thermal efficiency. This is typically insignificant to the other cooling benefits to aluminum." https://performancetrends.com/Definitions/Heads.htm See it in action: https://www.youtube.com/watch?v=jdW1t8r8qYc |
02-23-2022, 08:41 PM | #37 |
One of the exciting things I see here is maybe we can use a better exhaust system than with the standard port location. With the ports being higher, is it possible to use extractors with one of these heads in a RHD car?
Is there an ejector seat available too? |
02-24-2022, 11:04 PM | #38 |
I can't see how extractors would do much with low revs and low compression.
The primary tubes need to be long, and that's ugly. I gather the original exhaust manifold is not bad either. |
02-24-2022, 11:33 PM | #39 | |
https://www.snydersantiqueauto.com/p...9392&cat=41733 or https://www.snydersantiqueauto.com/p...9393&cat=41733 With the inlet and exhaust ports being higher on the engine, I think the exhaust pipe in front of the muffler would have to be longer than original so these headers might not be suitable. What do those who have used an OHV head done in the past? |
