06-01-2021, 08:27 AM | #1 |
Rubbing
Have a 29 special coupe, hard turn causes rubbing on front tire, all stock, 21” tires. Any thoughts?
06-01-2021, 08:54 AM | #2 |
Re: Rubbing
Tire is probably hitting the brake rods. It could be that the tires are oversize. Firestones are a bit oversized. you could fix it by putting a washer under the stops on the axle.
06-01-2021, 10:10 AM | #3 |
Re: Rubbing
Dont do any hard turns!
www.whidbeymodelaclub.com |
06-02-2021, 10:51 AM | #4 |
Re: Rubbing
Are the stop nuts on the front or rear of the axle?
06-02-2021, 12:12 PM | #5 |
Re: Rubbing
My Coker 21" radials are substantially larger than the multiple brands of bias rags I took off. They rub just a little in a tight turn.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. |
06-02-2021, 12:42 PM | #6 |
Re: Rubbing
Also, make sure they are the correct length and are touching the spindle. |
