07-20-2020, 04:18 PM | #1 |
'40 Radio Problem
'40 Philco plays weak on only one station. Discovered that momentarily touching antenna to ground with a 1.5 test light produces full volume on 6 stations for 8 minutes, then dies back.Same way in the car or on the bench. Know nothing about electronics. Can anybody help with this? Carl
07-20-2020, 05:08 PM | #2 |
Re: '40 Radio Problem
Guessing a capacitor problem, if your adventurous you could unsolder and replace the capacitors one at a time. Probably best to send it out for repairs.
07-20-2020, 05:14 PM | #3 |
That is a problem a repair shop that is familiar with old tube type radios needs to fix.
If you should open up the box be aware that there is a high enough voltage inside, when the radio is on, that will light up your ears if you contact it. |
07-20-2020, 08:58 PM | #4 |
Take a look at this fellow in northern Illinois. https://www.car-radio-conversions.com/
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
07-21-2020, 09:35 AM | #5 | |
Ken
https://www.nirgv8.org |
08-08-2020, 03:39 PM | #6 |
08-16-2020, 09:23 AM | #7 |
Get it converted to modern electronics. Mine even works on a thumb drive with pre recorded music. Also no static.
