06-19-2020, 12:03 PM | #1 |
1935 coupe overflow tank recommendations
Has anyone installed a radiator overflow catch tank on a 35 coupe? Need ideas / recommendations on how best to do it.
Bullshark P.S. I have the later style "B" radiator with the overflow tube front center on the radiator behind the grill. Last edited by Bullshark; 06-19-2020 at 12:11 PM. |
06-19-2020, 02:23 PM | #2 |
Re: 1935 coupe overflow tank recommendations
There are several ways to add an overflow tank. What I did to my '35 was to add an overflow tube (available from many sources) to my radiator housing. I pop riveted a couple of case nuts to the radiator side panel, bolted the tube to the radiator frame. Finally, I just ran a rubber hose from the radiator overflow to the bottom of the reservoir. The second hose is an outlet for the overflow if it fills up.
Hope this helps. Last edited by Tom-MI; 06-19-2020 at 02:32 PM. Reason: spelling |
06-19-2020, 03:17 PM | #3 |
Just curious if you are doing this because your radiator/temp pushes coolant out? If so - curious if you did the normal checks for actual coolant temp with a heat gun ... if your thermostats are working properly and your water pumps are doing their jobs. Just a thought if you are blowing water .. an overflow tank may be a band-aid ... but not the cure.
06-19-2020, 03:43 PM | #4 |
Car runs cool with adequately filled radiator. Pretty stock car, No thermostats installed. Running down the road 40-50mph with 4:11 differential, radiator fills up and blows out overflow tube. Then the syphoning takes over. Will probably have to get a pressure radiator cap as well, not sure. I have been told that large washers or punched out thermostats installed at water pumps to slow flow may fix.it but that comes later.
06-20-2020, 10:57 AM | #5 |
Why are you not running thermostats? It is very beneficial to the engine to bring it up to temperature as quickly as possible and maintain a minimum temperature. Something at least in the 180 - 185 degree range. IMO 190 would be better.
Running an engine to cool increases contaminates in the oil, increases engine ware and decreases engine efficiency. |
06-20-2020, 11:49 AM | #6 |
I just wired a plastic bottle near the bottom of my grill to catch any overflow, I can pour it back in the radiator if necessary. My car like your runs cool and only pushes out coolant at higher speeds. My level normally runs below the top of the tubes, if I fill to top of tubes, coolant is being pushed out at lower speeds, and the car does not run any cooler with that extra coolant. |
06-20-2020, 11:55 AM | #7 |
The car never had them initially I'm told. I dont drive it in colder weather and as a result it doesn't take long to stabilize at normal operational temperatures. I will be looking into that after I tackle the overflow tank. Today's oils are much better with temperature extremes. Do you guys use zinc additives for the valve train on these old flat heads? As far as engine efficiency, my old IC engine course taught us best efficiency comes with large temperature differential between intake air/ fuel vs combustion. I run my race engines with 160° Thermostat. Big difference between that and these old flat heads I know. Lol
06-20-2020, 12:19 PM | #8 |
Thanks for the heads up Cali.
06-20-2020, 08:54 PM | #9 | |
Second issue, there is a big difference between carburetor intake temperature and engine operating temperature. You want the coolest intake temperature (for performance, not necessarily for daily driving) you can get. That is totally different from engine operating temperature and has very little to nothing to do with thermostats. Internal combustion engines are heat engines, you are taking in a fuel/air mixture and converting it to heat. Any lost heat is lost energy. One of the goals of modern engines is operating at and maintaining increased temperatures, which is higher efficiency. That is the principal behind turbo changers, you are recovering some of the lost heat energy in the exhaust gases. The greater the operating temperature of an engine the greater the efficiency. On a flathead engine with an unpressured coolant system the best you can do is in the 190 to 195 temperature range. If you are running a race engine with 160 degree thermostats you are losing performance potential. You want the intake air cool, but the engine at as high an operating temperature practical. Any heat loss to the cooling system, exhaust, etc is lost heat energy. Last edited by JSeery; 06-20-2020 at 09:10 PM. |
06-20-2020, 09:21 PM | #10 | |
06-21-2020, 09:09 AM | #11 |
If you are looking just for a catch can any old empty beer can, conveniently located will work.
A catch and recover system requires a recovery cap and filler neck that fits the cap, along with a recovery tank.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 06-21-2020 at 09:17 AM. |
06-21-2020, 01:31 PM | #12 |
Not so in this case....with this style radiator, the overflow tube is mounted at the uppermost part of radiator. If you run the other end of the overflow tube into the bottom of a catchcan, as coolant expands, it will fill the catchcan, as coolant cools, the coolant in the catchcan will by the vacuum created, be drawn back into the radiator; the radiator will always be full to the brim, irrespective of coolant temperature....the secret is that the radiator cap must seal perfectly. I run this setup in my 35, have done for years with zero problems
06-21-2020, 03:08 PM | #13 |
A little different but on my Model A with a Quail radiator cap I made sure it sealed, bought an aftermarlet plastic tank at NAPA I think, ran a tube from the overflow tube to the tank, as stated above after shut down anything in the tank was sucked back into the radiator.
Paul in CT |
06-22-2020, 07:58 AM | #14 |
Thanks for everyone's input here, much appreciated. I think my take away will be along the lines of finding a inconspicuous catch can/ overflow tank small enough to fit in front of the radiator and behind the grill connected as described above so it sucks coolant back after cooldown. Hopefully larger than a beer can. I would like to keep the car looking as original as possible to the casual observer. Sorry for the "BAD" info J. I believe some car show guy that told me about large washers to restrict coolant flow and led me to believe the car didn't incorporate thermostats back then. I'll probably look into putting them back in if for no other reason than to help restrict the coolant flow to the radiator during high rpms.
In my case, the contribution of the thermostat value (160 vs 190) to engine thermal efficiency is very low, at least the way I understand it. Please chime in if I'm wrong J. I blow through the temperature range that the thermostats do any control in less than a few minutes. What is the thermal efficiency of these old 85hp flatheads anyway? Less the 20%? Much more sensitive to engine performance is probably combustion efficiency. Beyond the manual choke, I'm ignorant of how best to approach that on these old engines. Bullshark |
06-22-2020, 08:42 PM | #15 | |
160 degree thermostats are sure better than nothing. 175-180 would be much better and 185 to 190 range better yet. |
06-23-2020, 06:34 AM | #16 |
I was told to not fill the radiator to the max. but leave it over the top of the fins but allow enough room for the expansion of the water without getting it the overflow tube. this allowed for expansion and did not allow for the siphoning action to occur.. Worked for me.. kx
