05-25-2020, 06:58 PM | #1 |
How to age Caledon tubing?
Hi Everyone,
I'm going to replace a piece of gas line tubing with a new piece that I bought from Snyders but I want to give it that "patina" look of 50+ years old so that it doesn't stick out like a sore thumb next to everything else under the hood. Any ideas of what it's made out of and how I can age it without waiting another 50 years? Thanks,
John |
05-25-2020, 08:12 PM | #2 |
Re: How to age Caledon tubing?
I made a gas line out of hydraulic brake line tubing. It was a darker color sort of dark green.
05-25-2020, 08:30 PM | #3 |
A friend used to soak his Vw parts in brine to "age" them
05-25-2020, 09:09 PM | #4 |
You could try soaking in salt water which would do the job pretty quickly.
"The more things change, the more they stay the same." |
05-25-2020, 09:22 PM | #5 |
If it has a plating type coating on it a dip in muratic acid and water mix of 50/50 will most likely take it off leaving it bare steel. If you want it to have a rusted type look spray it with salt water mix and let dry. Spray and let dry. Repeat, repeat, repeat. Drying in between is important as steel needs oxygen to rust.
Dave / Lincoln Nebraska |
05-26-2020, 03:54 AM | #6 |
I use linseed oil, leave item in the sun, or bake lightly after applying. You're not trying to cook it. Just dry it. I left a set of new keys dipped in linseed oil on top of the toaster for a few cycles. Dried ok. It ages & goes brown rather quickly when heated.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
05-26-2020, 08:16 AM | #7 |
The original gas line was terne coated seamed steel tubing. Terne is an alloy of less than 20% tin, sometimes 1 or 2% antimony, and the remainder lead. It quickly aged to a dull 20% brightness gray color. The quickest cover up that is about the same appearance and that will hold up without damaging the new line is a rattle can of dull zinc rich 'galvanize'. Not the expensive shiny stuff, the standard dull kind.
Of course, if you are into fine-point or want the absolutely untouched, un-restored, all original parts look, you can get a long length of today's electro-zinc plated steel line, set up a fixture and profiled tool bit to cut the appearance of the original seam, mix up your own terne, use an acid flux and a pad like an old-time plumber making a wiped joint, and wipe the terne onto the tube at about 700F. Then if you want the aged look just wait! |
05-26-2020, 04:51 PM | #8 |
For quick darkening, you might try scuffing it with a scotchbrite pad and wiping some old black waste oil on it to get some carbon in the new scratches.
05-26-2020, 09:47 PM | #9 |
Thanks for the ideas so far guys, keep them coming.
John |
