05-04-2019, 08:13 AM | #1 |
How’s your Shortened pitman arm working?
Just wondering All of you out there that have installed the shortened Pitman arm how much of a difference it makes and how do you like it versus stock?
Isaiah B. 1928 all metal Tudor |
05-04-2019, 08:23 AM | #2 |
Re: How’s your Shortened pitman arm working?
I installed a new one from Snyder’s on my ‘30 Tudor. Steering is much easier. This is the second one I have done. I always use a new one, never a welded one.
Jeff P./MN 1913 Model T Runabout 1926 Model T Sport Touring 1948 Chrysler New Yorker |
05-04-2019, 08:25 AM | #3 |
I have a shortened pitman arm on my 30 Tudor that I use for touring. In over 16 K miles, I would not change back to original. I have 19 inch wheels and tires.
It steers easier and I would recommend it for those who have the original steering box. The steering box must be in good condition as well as the other steering components. DO NOT use a shortened pitman arm with the F100 conversion. It makes the steering too slow and imprecise. My opinion, Chris W. |
05-04-2019, 09:34 AM | #4 |
It's like power steering by comparison. However it does put just a little more slop into my sloppy steering and increases the radius of a turn but I recommend them. gary.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
05-04-2019, 09:48 AM | #5 |
I like it, I think you will too.
They are not expensive so throw one on, quick and easy.
05-04-2019, 09:49 AM | #6 |
05-04-2019, 10:09 AM | #7 |
I have a new one, not welded and it works fine with my rebuilt F100 box. Much better than the 7 tooth I had rebuilt. It still turns lock to lock, so I don't seem to suffer the longer turning radius others speak of. I takes more turns to get there but if moving at all it isd a one finger pull on the steering wheel. Made my own box so I cost just about 200 bucks. I used a 56 Ford pickup unit.
05-04-2019, 10:16 AM | #8 |
I liked it so much in my 190A that I bought one for my 45B also.
Bob Bidonde |
05-04-2019, 10:57 AM | #9 |
I put a new one about 5+ years ago and it made a difference with no complaints.
05-04-2019, 11:06 AM | #10 |
I use the shortened pitman arms from Wiley Higgins in Cumming Georgia . I am well pleased and use the shortened pitman arm on most of my model A's . When moving , they steer about as easily as power steering .
05-04-2019, 11:06 AM | #11 |
I made one back in 1960 for my widebed, bought one for my tudor with the F-100 box a few years ago and have a AA arm on my speedster. I'm happy with all of them. A shortened arm is even more important if the car has been lowered as everything lines up better.
05-04-2019, 11:19 AM | #12 |
Everyone is saying they make the steering easier but is there not a downside?
At 45 to 55mph would you notice the loss in steering precision?
05-04-2019, 11:43 AM | #13 |
I have a stock 2 tooth steering box in my '30 Town Sedan and my steering still goes lock to lock also. I don't seem to suffer the longer turning radius others speak of either??
05-04-2019, 11:50 AM | #14 |
What is the length between the centers on the shortened Pitman Arm's?
Regards Bill |
05-04-2019, 11:52 AM | #15 |
I bought one of Rainmaker Ron's shortened Pitman arms many years ago. Love it.
Miss Ron! |
05-04-2019, 12:09 PM | #16 |
05-04-2019, 02:14 PM | #17 |
I just got one from Bert’s and at some spots it’s twice the thickness of the original one. I have not installed it yet.
05-04-2019, 02:15 PM | #18 |
I did just pick one up from Bert’s but have not put it on the car yet.
05-04-2019, 02:16 PM | #19 |
Great question.
05-04-2019, 02:55 PM | #20 |
It has been said that a shortened pitman arm will increase the turning circle . In other words the car would require a larger area to turn around in a circle . This hasn't been a problem for us . Some have had more problems with the 28-29 models . The problem in sush cases has been that the shortened pitman arm couldn't pull the spindle back quite far enough to reach its stop . This in turn increases the turning circle .
