02-10-2019, 02:43 PM | #21 |
Re: Spring Lube ?? Additional....
Hello,
If the individual springs in the spring package are not lubricated and glide badly and differently, then the spring leaves, which glide easily, must additionally absorb the force from the leaves, which glide badly. This overloads them. Wherever a relative movement takes place, friction and wear are created. Therefore, it must be lubricated there. In the picture you can see how the upper spring leaf worked into the lower one, because the spring ran dry. About 0.3 millimeters!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
02-10-2019, 03:37 PM | #22 |
Petroleum based lubricants and the abrasives in road debris combine to make lapping compound,fine for seating valves,bad for springs.Ford vanadium steel leaf springs are no different than modern leaf springs made today,all spring packs (a stack of leaves is called a pack)when assembled are assembled clean and dry to insure the center bolt clamps the leaves together and bears proper load to hold the leaves in alignment,any lubrication would deter the ability of the center bolt to work,its how leaf springs ultimately fail,through wear the tension on the center bolt degrades. Spring packs 'lubricate' and remain rust free through action.in the above photo the leaves are worn due to use,they have achieved the end of their life cycle,lubrication would have accelerated the failure.
02-10-2019, 04:12 PM | #23 |
That's not true.
The centering screw only has the task to center the spring package in the middle. Not more! Holding the spring package is done by the two briden / bars, which fixes the entire package with the four very thick screws. If the spring had been lubricated properly, it would have no abrasion / wear!
02-10-2019, 06:06 PM | #24 |
There is a lubrication point in the hand crank bearing to drool on the center bolt and onto the spring to lubricate it in the crossmember
02-10-2019, 08:48 PM | #25 | |
02-10-2019, 09:15 PM | #26 |
02-11-2019, 01:29 AM | #27 |
While the bolt does hold the spring pack together before assembly, the center bolt job is to keep the leafs in alignment when installed, the clamps hold the spring in place in the channel and apply clamping force to each side of the center bolt. Plenty of A's have broken center bolts and they don't have exploding springs, the leafs may shift but they don't explode under the car.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 02-11-2019 at 01:39 AM. |
02-11-2019, 01:18 PM | #28 |
I just picked up a very rusty spring that had been stored outside for decades. I am planning to break it down for cleaning and painting. Is it possible to slide the clamps off and back on? If not what are my options?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
02-11-2019, 01:32 PM | #29 |
If you are talking about these;
https://www.snydersantiqueauto.com/rear-spring-clamps Maybe not. They have a locating pin that fits into the leaf. You would still need to take precautions because the springs are still are under tension even if it's old and rusty.
I know the voices aren't real but damn they have some good ideas! |
