Old 02-03-2019, 09:42 PM   #1
Fibber Mcgee
Fibber Mcgee's Avatar
Default Tod?
What happened to Tod and his new Flathead?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 02-03-2019, 10:58 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Tod?
My error, deleted post.
Old 02-03-2019, 11:44 PM   #3
Fordors
Default Re: Tod?
He has mentioned that the foundries have been screwing him over and at this time he is backed up machining 4 banger heads and intake manifolds for Snyder’s. To get around the foundry hassles he is working toward setting up a small in house operation to suit his needs. He has machined four cylinder blocks in both iron and aluminum, and there will be an available five main option for those but the V8 block has not progressed past the design stage AFAIK. Seems like the last he posted on that project was he had redesigned the V8 ports.
He posts on the HAMB using the screen name 427designer but it’s not very often he does, I assume he is just too busy.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
