Old 11-27-2017, 09:59 PM   #1
Classiccanuck
Classiccanuck's Avatar
Default 28 Phaeton seat springs
I bought new seat springs from Snyders, is there any wood on the seat springs bottoms where they contact the risers? I never had any originals to compare with. I would think that once they are upholstered, contact with the seat risers would wear the vinyl out prematurely along the bottom edge.
Classiccanuck is offline   Reply With Quote
Old 11-27-2017, 10:57 PM   #2
Phred
Phred's Avatar
Default Re: 28 Phaeton seat springs
No wood. The upholstery material does not rest directly on the the metal seat platform either. The bottom rim of the cushion and material is encapsulated in thin sheet metal, protecting the upholstery material. The seat cushion rests metal on metal on the seat platform. Might be able to post photo later.
Peace, Phred
Phred is offline   Reply With Quote
Old 11-27-2017, 11:15 PM   #3
Classiccanuck
Peace, Phred
Thanks, a few pics would definitely help
Old 11-27-2017, 11:54 PM   #4
Dick Carne
Dick Carne's Avatar
The seats in my (January) '29 phaeton were upholstered back in the mid-to-late 1960's, but there was no provision for any thin metal encapsulation on the seat spring sets that were available at that time. The same was the case when I upholstered my '28 roadster in the mid-1980's, using seat springs that were available at that time. Consequently, the upholstery material comes in direct contact with the seat frames on both cars. It does seem to me that it would be preferable to have a metal-to-metal contact instead of material on/against metal, but neither set of seat springs in these cars does, and despite that, the upholstery material has held up quite well on both cars. Hope this helps. Good luck on your project.
Dick Carne is offline   Reply With Quote
Old 11-28-2017, 12:45 AM   #5
updraught
updraught's Avatar
http://i.ebayimg.com/00/s/Mzc1WDUwMA==/z/GVkAAOxyUylTVl0k/$_3.JPG?set_id=2
https://i.ebayimg.com/images/g/awkAA...dm/s-l1600.jpg
https://www.ebay.com/itm/1928-1929-1...-/162751319712
Some photos from ebay. I think our seat springs might have had a wood tack strip due to local content (?).
updraught is offline   Reply With Quote
Old 11-28-2017, 07:08 PM   #6
Classiccanuck
Thanks, just wondered how they were done originally
Old 11-28-2017, 09:04 PM   #7
iverson
iverson's Avatar
Our June 28 touring has the metal around the edges
iverson is offline   Reply With Quote
Old 11-28-2017, 10:44 PM   #8
Classiccanuck
Thanks!
Old 11-28-2017, 11:03 PM   #9
Randy in ca
Randy in ca's Avatar
There should be a piece of wood running side to side under the middle of both the front and rear seat springs for support. If you're not familiar with it I probably have some pictures I can post.
Randy in ca is offline   Reply With Quote
Old 11-29-2017, 09:31 AM   #10
Classiccanuck
thanks Randy in ca
Old 11-29-2017, 12:47 PM   #11
FordyForever
FordyForever's Avatar
Red face Re: 28 Phaeton seat springs
My non-original 28 Phaeton has newish seats and I have two problems with them that might be of interest to you, before you spend any money on your car seats.
1) The front seat doesnt "sit" properly - when slid into place the bottom of the springs catch on the supporting cross-strut and the seat won't go under the back rest properly. I'm thinking of lining the seat pad with a thin sheet of hardboard to try to stop this - I reckon a sheet of metal might be squeaky?
2) The (fixed) back rest is very thick and my 6' son would be more comfortable driving with more leg room. So I'm thinking that it might be better to get the seats reupholstered to make the back rest thinner, and the seat cushion fit better.
I'd also be grateful for any comments about this.
Thanks so much
Cags
FordyForever is offline   Reply With Quote
Old 11-29-2017, 01:08 PM   #12
d.j. moordigian
d.j. moordigian's Avatar
Would you measure the metal and give us the height, on each side, please.
I need to make some up for my car..
Thank you!
d.j. moordigian is offline   Reply With Quote
Old 11-30-2017, 10:12 AM   #13
wrndln
Dudley,
The metal around the bottom edge of open car and pickup seat springs are part of the springs, not separate pieces. I have a couple of seat cushion springs made by Snyder's. I can take some pictures of them, showing the bottom metal trim. There is piping sown into the seat upholstery covering that is crimped into the metal on the bottom. My concern is how to get a nice looking crimp. I have seen some pretty poor looking crimp jobs on open car and pickup seat cushions. I don't know how Ford did it, but their crimping looks pretty good from the few original seat cushions I have seen. I think the repro springs are made just like the original seat cushion springs from what I can tell.
Rusty Nelson
Old 11-30-2017, 12:57 PM   #14
john charlton
john charlton's Avatar
Hi FordyForever . It looks like your phaeton is RHD so most likely in from Argentina or Uruguay . My experience with these cars is that sometimes way too much padding is used and also a lot have lost their original seat springs. My 28 ex Uruguay phaeton has seat springs on a wood base but they do fit well and the edges drop beneath the seat base retaining lip .
John in cold snowey Suffolk County England .
Old 11-30-2017, 01:01 PM   #15
Classiccanuck
I also bought my springs from Snyders, going to take a closer look at them now.
Old 11-30-2017, 02:16 PM   #16
d.j. moordigian
Originally Posted by wrndln View Post
Dudley,
Rusty Nelson
Rusty,...I have thought about what you said,...IF the bottom edge is part of the
lower seat spring,..how do you upholster, with that piece in the way?
I kept thinking it was separate,..then crimped,.to seal off the edge..
Old 11-30-2017, 04:30 PM   #17
Classiccanuck
that would make sense
Old 12-01-2017, 11:52 AM   #18
d.j. moordigian
Dudley,
Rusty Nelson
Okay,..after seeing photos Rusty is CORRECT and I believe the repops are
also correct.
Old 12-01-2017, 12:05 PM   #19
wrndln
I sent some pictures of the botom of open car seat springs made by Snyder's to Dudley. Am posting them here so other people can see what they look like.
Rusty Nelson
Old 12-01-2017, 10:44 PM   #20
iverson
iverson's Avatar
I tried to get some pics I will try to do better when I get a chance in daylight it looks to me the strip is put on after upholstery
