09-21-2017, 11:42 PM | #1 |
Cleaning a radiator
I have a 1941 Ford radiator that came on my truck. When I checked, the local radiator shop was going to charge within $20.00 of what a new aluminum one would cost to check my old radiator and rod it out. So I bought an aluminum one.
Now I find (8 years later) I need a radiator to check out my current flathead build on the run-in stand. I don't want to buy a radiator because I don't know what I am going to put the engine in and I don't want to put the old radiator on a fresh build with a clean block without cleaning it out. I have searched and most suggestions I found are for techniques with engines running in the car. I need some ideas with the radiator off the car.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
09-22-2017, 03:10 AM | #2 |
Re: Cleaning a radiator
Take the top tank off,Ann easy job,use a small gas burner and your air gun from the compressor to blow the melted solder out,clean the tubes,clean and tin the tank and top plate stick it back on .
I used a special radiator solder that was about 3/16 diameter. after that my 33 will run in 42-44 C temps and not get hot,thats even towing. Lawrie |
09-22-2017, 05:27 AM | #3 |
I have had 2 goes at rodding out a radiator and both were not real good.
Caused or got a multitude of leaks . Used snake oil in them after and it was satisfactoy to plug the leaks. But only worth it if you have the time to chance it. |
09-22-2017, 06:33 AM | #4 |
Might also use a cheap modern radiator and get creative with the hoses? Just a thought.
Tommy |
09-22-2017, 03:05 PM | #5 |
Plug the bottom outlets and fill with vinegar or evaporust and let sit. Flush and backflush. Some guys use lye, etc.
Ck on the A forum for "radiator cleaning". Paul in CT |
09-23-2017, 08:23 AM | #6 | |
block the bottom outlets and soak with whatever for a few days. Then rinse out and blow tubes clean. G.M.
www.fordcollector.com |
