07-31-2017, 09:40 AM | #1 |
spark plug question
Which plug is better Champion or Autolite?
Also which number plug? Also is there any real advantage to using the "Show Plugs" sold by Sneider's or Bratton's? I have a very nice driver !930 Coupe that is straight stock except for the generator - replaced with a alternator TIA Chris Union, ME |
07-31-2017, 09:54 AM | #2 |
Re: spark plug question
I think you'll find it is more of a personal preference. Either plug will work fine. I don't like autolite plugs for modern cars but they work great in my A and T. I'm sure you'll find some with the same opinion about Champions. There is no advantage to using show plugs unless you're car is being judged in a show. They do not perform any better.
07-31-2017, 10:03 AM | #3 |
If your engine is running nice use your preference plug in the same heat range.
08-01-2017, 01:03 AM | #4 | |
Here is a link that will tell you how well your plugs are working for the heat range. heat range test Hotter to colder
