Old 09-21-2016, 07:22 AM   #1
jr-41ford
jr-41ford's Avatar
Default Melling M-15 Flathead Ford, High Volume Oil Pump
City: Pasco
State: WA
Price: 125.00
Melling M-15 Flathead Ford, High Volume Oil Pump with the Speedway Motors pick-up tube.
The oil pump is used, approximately 5,000 miles and works great. It pumps 25% more volume than the standard Ford flathead motor. The high volume oil pump may require oil pan modifications.
The high volume oil pump is approx. 1-1/4" deeper than an OEM '49-'53 oil pump. The bottom of the pan will most likely require modification to accept this additional depth. If this pump is to be used '48-older block, you will also need the Speedway Motors pick-up tube 910-16259. Pump measures 5-1/2" from mount surface to bottom of the pump.
I removed the oil pump from a tired Ford Flathead, am moving and have no use for the pump at this time. Asking $125.00.
If interested please shoot me a PM or give me a phone call @5095547499 instead of a text message. I am not real quick to reply text messages.
jr-41ford is offline   Reply With Quote
Old 10-03-2016, 06:59 AM   #2
jr-41ford
jr-41ford's Avatar
Default Re: Melling M-15 Flathead Ford, High Volume Oil Pump
Price change, $100 obo.
Old 10-15-2016, 06:43 AM   #3
jr-41ford
jr-41ford's Avatar
Price change, $75.00.
