04-30-2016, 08:44 AM | #1 |
Finally Fume Free
After owning my tudor for 5 years have finally resolved my gas fume issues. Started out with dripping carb - fixed, steering wheel bracket - fixed, gas gauge - fixed. Still had fumes after these fixes & couldn't find the source after many attempts. Finally got the idea of pressurizing my tank, Got a radiator cap, drilled a small hole in it, soldered a brass tube through the cap. Hooked up to my air compressor & put 5lbs pressure in the tank, immediately heard hissing and found a small hole in the top of the tank. Now repaired and finally fume free motoring.
04-30-2016, 09:02 AM | #2 |
Re: Finally Fume Free
And that's the way it's done....
Good work LEADPOT
04-30-2016, 01:04 PM | #3 |
Now that's ingenuity – I’ll have to remember that trick.
Glad you found it!
I Love Anything That Turns Money Into Noise |
04-30-2016, 02:01 PM | #4 |
Two gaskets on the gas cap and pipe fittings from gas outlet works also! Cheaper :-)
04-30-2016, 02:37 PM | #5 |
The only time I get gas fumes in the cab is when my Son in-law rides with me, I think he has a four chambered stomach, the young man is worse than cattle.
04-30-2016, 04:23 PM | #6 |
04-30-2016, 04:57 PM | #7 |
Only 5 lbs! You could have increased your cruising range with a little more.
Well done, McGyver.
04-30-2016, 05:28 PM | #8 |
04-30-2016, 06:28 PM | #9 |
04-30-2016, 06:49 PM | #10 |
Excellent fix...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
04-30-2016, 11:21 PM | #11 |
That's tackling a problem!!!
05-01-2016, 12:56 AM | #12 |
You mean ppphhhhhhhh hhhhhh hhaeton
