Old 04-19-2016, 01:52 PM   #1
1929
Default Riley dual intake manifold?
where can I get a Riley dual intake, or is it only maybe on Ebay?
1929 is offline   Reply With Quote
Old 04-19-2016, 02:39 PM   #2
Sparky
Sparky's Avatar
Default Re: Riley dual intake manifold?
Original or repro?
Repros here: http://secretsofspeed.com/intake-manifolds.htm
Sparky is offline   Reply With Quote
Old 04-19-2016, 03:14 PM   #3
Fordors
I have an original Riley log style, but Charlie Yapp made a plenum style for his Riley 2 port reproduction. The repro manifold from Yapp is called the Equalizer, takes two 3 bolt carbs and I think is still available. There are differences between the Riley and stock Model A bolt hole spacing for the manifold, but the Equalizer is machined for both.
The manifold I have has 1 5/8 intake ports and the carburetor flanges are sized for 1 7/8 Winfield CC carbs. Center to center of the intake port bolt holes is 2 11/16 and stock c-c is 3 1/8. I mention all this because I believe you have a Riley 2 Port but don't know for sure.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 04-19-2016, 06:31 PM   #4
hardtimes
hardtimes's Avatar
Is this the intake that you are asking about ?
I don't think that it is made like this anymore. This one is over a decade old and maybe the first made, as back when I 'got ahold' of this one, none were available for sale yet.
There is an un-machined carcass that can be adapted/welded for updraft, I think ? There is an 'equalizer' name on the manifold, but not like the one pictured here. I might be wrong, so contact C. Yapp for the final word on availability
BTW..the BIG selling point was made that this intake...'has an equalizer plenum' built into it' !
Old 04-19-2016, 07:21 PM   #5
Fordors
The manifold is still produced, but without the RiLEY name on it, as Rick mentioned above. Originally marketed with his reproduction Riley 2 Port heads I think he changed the name to Equalizer when the repro heads sold out. BTW Charlie Yapp marked his Riley stuff with the small i to differentiate it from original Riley parts.
Old 04-19-2016, 07:58 PM   #6
Mikeinnj
Mikeinnj's Avatar
To fit the "Equalizer" intake with a stock exhaust manifold requires some machine work to clear the side valve cover and exhaust manifold . . . AND the mount feet must be cut straight down through the middle of the four OUTER holes to make them like "crow's feet".
Mikeinnj is offline   Reply With Quote
Old 04-19-2016, 09:26 PM   #7
1929
BTW..the BIG selling point was made that this intake...'has an equalizer plunum' built into it' !
That or the down draft that Early Ford Store still has not removed from their Website.
Old 04-19-2016, 11:41 PM   #8
quickchange
quickchange's Avatar
1929 We currently having a batch cast , ready mid may . dual , finned, riley ,
quickchange is offline   Reply With Quote
Old 04-20-2016, 04:38 AM   #9
waxhead
waxhead's Avatar
Do you have any pictures of these??
waxhead is offline   Reply With Quote
Old 04-20-2016, 04:49 AM   #10
quickchange
Yes but can,t seem to list here only by starting a new thread , mail me direct [email protected], I am away as of midday 21st for 3 weeks at Pate swap meet .
Old 04-20-2016, 04:55 AM   #11
Juggler
Juggler's Avatar
Here you go Derek
Can you do a single carb version?
Cheers
A
Juggler is offline   Reply With Quote
Old 04-20-2016, 06:13 AM   #12
1929
Originally Posted by Juggler View Post
Here you go Derek
Cheers
A
That's a beauty, that's what I want.
Old 04-20-2016, 02:34 PM   #13
quickchange
No only do a dual one . like a female two is better than one ? jugs we are talking about , Thanks Andrew for posting , bag packed & on the plane this morning , Texas here we come yahoo.
Old 04-21-2016, 04:54 AM   #14
waxhead
waxhead's Avatar
Nice, thanks for posting the pics
Old 04-21-2016, 08:47 PM   #15
quickchange
Thank Andrew , We just landed in Texas & ready for swap meet in the morning , New Brumfelt Report tomorrow night
Old 01-31-2024, 01:36 AM   #16
Chris Haynes
Chris Haynes's Avatar
Hardtimes,
Looking at your picture I see no linkage going to the rear carburetor. Are you only using one?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2024, 06:07 AM   #17
WRA
WRA's Avatar
Thread is pushing 8 years old.
Dual Strombergs have linkage on the other side.
WRA is offline   Reply With Quote
Old 01-31-2024, 07:04 AM   #18
Bruce of MN
Bruce of MN's Avatar
The item circled in yellow might be the linkage:
Old 01-31-2024, 12:32 PM   #19
Chris Haynes
Looks like a heat shield under the distrubutor.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2024, 04:19 PM   #20
Bruce of MN
OOPs!
