Old 04-11-2016, 04:51 PM   #21
C26Pinelake
Default Re: Model A Rear Wheel Bearing
Originally Posted by Franchise_24 View Post
Has anyone had any luck on buying the grease seal for the rear wheels at any local stores?
It might cost a few bucks more but you can buy the entire package at Snyders. Sometimes all the running around does not justify the small amount of money saved. Wayne
C26Pinelake is offline   Reply With Quote
Old 04-11-2016, 07:08 PM   #22
Bud
Bud's Avatar
The spiral rollers were made for a specific purpose, and grease was a distant second. These are shock-absorbing roller bearings. When the wheel hit a pothole or other obstruction, instead of a high contact stress seen at the rollers, the spiral roller elongates (it is a spring) thus reducing the stress. Modern bearings are solid because it is just less expensive to make them that way. But with better roads, perhaps it is a wash. The shock absorbing roller bearing is another quality feature of Model A's.
Bud is offline   Reply With Quote
Old 04-11-2016, 07:13 PM   #23
Larry Jenkins
A-1224
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
