01-05-2016, 09:46 AM | #1 |
front brake grabs 1952 ford customline
adjusted brakes thought did right now when starting out sometimes front right brake grabs make loud squealing sound thats the best way to describe.. .to begin petal was down a little from normal so decided to adjust ,, adjustment brought pedal to normal then the grab squeal
01-05-2016, 09:56 AM | #2 |
Re: front brake grabs 1952 ford customline
Sounds like you may have a leak. Pull the drums and check.
01-05-2016, 10:12 AM | #3 |
Did you check the shoes? The short shoe goes in the front on 49 and later cars.
01-05-2016, 04:41 PM | #4 |
thanks to all and no havent looked yet and now with winter hitting may have to wait till spring which is about march or april here
01-05-2016, 05:12 PM | #5 |
Don't drive it until you remove both front drums and see what is happening. Something is clearly not right, maybe a spring broke. If that is the case, replace them all as they are over 60 years old.
01-05-2016, 06:37 PM | #6 |
That being said, if a drum was put on that was turned way beyond limits, the adjuster could screw all the way apart and crap fall down to make scraping noise. Back when I was in the garage business I actually had Fords come into my shop this has happened to, with symptoms very much like yours.. |
01-05-2016, 07:59 PM | #7 |
I once had a wheel cyl. freeze up car pulled to opposite side. Dave
01-05-2016, 09:15 PM | #8 |
It could be a problem with the left side not working properly and the right side ok, thereby pulling to the right.
A squeak usually means metal to metal. I would assume the left side is the problem.
01-05-2016, 10:16 PM | #9 |
the funny part is it doesnt pull at all and in days gone by had em pull hard.....lt well could be a spring broke thanks all dennis
01-06-2016, 10:04 AM | #10 |
Look for wet shoes. You had a low pedal which indicates a leak. Brake fluid causes them to swell and bind.
01-06-2016, 04:37 PM | #11 |
I had the same problem on my Falcon . It was a leaking wheel cylinder .
