Old 12-05-2015, 08:15 PM   #1
cfordman
Unhappy Electric fuel pump durability
ran my A out of gas today the electric pump ran for a min or so before I shut it off. tried cranking it for another min or so and again when I added gas. on troubleshooting no fuel to carb I pulled the pump checked the filter which was clean and bench checked the pump it makes the same noise it always did but wont pump (airtex rotary pump). can you fry the seals running it without gas for as short a time as this? tried tapping it while running, didn't help. just noise-no pump.
cfordman is offline   Reply With Quote
Old 12-05-2015, 08:19 PM   #2
Mitch//pa
Default Re: Electric fuel pump durability
airtex are one of the worst pumps on the market... i have had more CB's on modern iron from that brand screw them A***S.. . carter, delphi, holley are some of the better ones...
Old 12-05-2015, 08:40 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Can you take it apart to check the moving parts for wear? I have 2 Holly and 1 Carter rotary pumps, and they can easily be taken apart to check the vanes for wear.
Old 12-06-2015, 12:57 AM   #4
CWPASADENA
CWPASADENA's Avatar
What's an "Electric Fuel Pump"? or better yet, What is a "Fuel Pump"? I do not seem to have one on my Model A. May be I am missing something???
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-06-2015, 09:09 AM   #5
kenparker
kenparker's Avatar
An "Electric Fuel Pump" is the generator. It pumps out electricity which is the "fuel" that runs the distributor and the lights.
kenparker is offline   Reply With Quote
Old 12-06-2015, 11:06 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Had an old AUTOPULSE electric pump on our Indian powered 3/4 Midjet.. After it was started, turn OFF the pump, the VIBRATIONS would cause the pump to pump!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-06-2015, 10:08 PM   #7
cfordman
tom, nope its sealed. tried it again today can hear the rotors spinning but no suction. as long as the tank is full I can use gravity ( its still free) ive built a speedster pick up with a T ten gallon tank in the bed and somewhere below half tank its height levels off with the carb. im just surprised it failed with less than three hours of actually running in the last year. I use mm oil in the gas. It looks like they don't like to be run dry.
Old 12-06-2015, 10:30 PM   #8
Dodge
I had one that sat for awhile and it was doing the same thing. I took it apart and the
diaphram looked like a piece of chewed up bubble gum. I think the material they used
wasn't compatible with the new crappy gas.
Dodge is offline   Reply With Quote
Old 12-06-2015, 10:42 PM   #9
denis4x4
denis4x4's Avatar
There is one school of thought that says shutting off the gas lets the fuel pump diaphragm dry out and causes failure.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-06-2015, 10:48 PM   #10
Tom Wesenberg
Flexible impellers, gears and vane pumps shouldn't be run dry, but I'm surprised it would be shot if it only ran dry a few minutes.
Have you tried to prime it?
Old 12-07-2015, 08:20 PM   #11
cfordman
cut open the pump, whatever is inside is encased in epoxy, no way to tell what failed. will buy a better brand pump.
Old 01-01-2016, 03:56 AM   #12
Allanw
Allanw's Avatar
Agree!
I had an Airtex replacement pump in my Wifes old Subaru. It whined so loud (stright out of the box!) that you could still hear it at 60MPH.
The 3 replacements I requested were the same, I evenbtually got a Walbro which was perfect, and I still have the airtex on my shelf, to remind me how crappy they are!
I'll never buy another.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 01-01-2016, 11:41 AM   #13
captndan
captndan's Avatar
I just have to ask. Why would anybody put a fuel pump on an A?
captndan is offline   Reply With Quote
Old 01-01-2016, 12:25 PM   #14
SeaSlugs
SeaSlugs's Avatar
Originally Posted by Allanw View Post
Agree!
also agree, people over on a chevy s10 forum say the same things - lucky to get 6mo out of the pumps.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-01-2016, 12:50 PM   #15
Tom Wesenberg
When people use a downdraft carb, then it sets higher than the bottom of the gas tank, so it needs a little pressure to fill the carb.
Old 01-01-2016, 08:30 PM   #16
Synchro909
Synchro909's Avatar
I have 3 A's, all with electric fuel pumps and down draft carburettors. All 3 pumps come from old Subarus - ones with carby's. They are cheap, quiet and supremely reliable.
(Now that I have said that, watch, one will fail.)
