09-05-2015, 07:06 PM | #1 |
radiator foaming over
If i run anything besides straight water in my radiator, it foams over under the slightest load and increased rpm.
09-05-2015, 07:54 PM | #2 |
Re: radiator foaming over
Check for exhaust gases in the radiator.fill it to the neck, and hold the engine at 1000/1200 rpm for a half a minute or so, and watch for bubbles.
09-05-2015, 08:43 PM | #3 |
09-05-2015, 08:46 PM | #4 |
i never had regular antifreeze foam on my cars. dont over fill the rad, it should be at or just below the baffle.. also ck for combustion gasses as mentioned
09-05-2015, 08:47 PM | #5 |
The "non-foaming" type is Sierra.
09-05-2015, 08:50 PM | #6 |
Or, if you are close to a shop such as Mitch has, then you could have them check for exhaust gases in the radiator by using an electronic sniffer. |
09-05-2015, 08:53 PM | #7 |
Sierra is one of the brands of Propylene Glycol (not ethylene glycol) anti freeze that foams much less. HOWEVER many people run regular antifreeze with no foam problems. It only foams when it aspirates from the pump whipping up gasses. Chuck/Sea/Tac is absolutely correct about combustion gasses leaking through/past a head gasket, particularly as load & cylinder pressure increases.
The question is do you want to fix the problem or treat the symptom? |
09-05-2015, 08:59 PM | #8 |
Tom,
we use our emissions gas analyzer to sniff the cooling system for hydrocarbons.. HC's i also have the kit you can buy at most outlets http://www.amazon.com/UVIEW-560000-C.../dp/B000NPDL76 but on very small leaks its tougher to diagnose with this... its better than nothing |
09-05-2015, 09:09 PM | #9 |
Many times, you can even smell the combustion gasses @ the filler, with your own SCHNOZZOLA. You could re-torque your head bolts, "MIGHT" help??
Bill W.
09-07-2015, 04:18 AM | #10 |
Our foamed like a bar-steward, untill we had the radiator rodded out, so it cooled properly.
Climbing hills, it would gush foaming coolant all over the place, even out the radiator cap. 4 goes with chemical flush did nothing. Rodding it out cleaned out a cup and a half of rusty, shitty crap. Since then, it's NEVER done it again, plus we've added a thermostat. I think we did some damage to the headgasket, as it started leaking about 500 miles later, so the head is off now. I'd get yours cleaned out too.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
09-07-2015, 10:13 PM | #11 |
I have had suggestions such as puttin a restrictor in the upper radiator hose to keep the water in the block longer. I got instructions with my leakless water pump to trim off part of the water pump impeller so it doesn't pump the water quite as fast. Have tried neither method. It seems to me that cutting off part of the impellars could upset the balance and wear out the bearings ??
09-08-2015, 01:10 AM | #12 |
Install a thermostat if you haven't already done so. This will hold back the coolant until the engine reaches the correct operating temperature. If will also slow the flow slightly, so the top tank is less likely to fill to the top and flow out the overflow pipe and onto the ground.
09-08-2015, 02:05 AM | #13 | |
http://www.autozone.com/loan-a-tools...er/391378_0_0/
09-08-2015, 03:40 AM | #14 |
I agree with Tom, I've seen this fix the boiling. Basically just re-torquing the head bolts.
