08-29-2015, 07:22 PM | #1 |
Left Rear Wheel Won't turn
Wheel will turn freely if the axle nut is loose. If I tighten it, it won't turn. I don't mean if I torque it to specs. If I tighten it just a little more than finger tight, it won't turn.
Here the back story. New drums, old hub. New wheel bearing, seal & snap ring. Service and e-brake rods disconnected. Adjusting wedge backed out all the way. Everything brake wise is new. Car is up on jack stands. Running in third gear, hand throttle set for 35 mph on the speedo. All is well until I tighten the axle nut. Yes, I stop it first before tightening. Right rear is fine. What's putting it in a bind? |
08-29-2015, 07:44 PM | #2 |
Re: Left Rear Wheel Won't turn
I would pull it off and see if the side of the shoes are rubbing on the drum or the drum
is hitting the backing plate. Bob |
08-29-2015, 11:32 PM | #3 |
probably worn axle taper shoving the drum too far on and binding everything.
08-30-2015, 12:08 AM | #4 |
tighten nut to where the wheel is hard to turn, force turn the wheel then pull it and look for places that have a wear mark on it, backing plate, inside of the drum or marks on the brake shoes
08-30-2015, 12:34 AM | #5 |
Try adding a tapered shim to the axle shaft. Suppliers sell them, or you can make one out of a soda can. Wear on the axle taper or the inside of the drum hub is allowing the drum to go on too far and the drum is rubbing the backing plate or the outboard edge of the shoes.
Tom Endy |
08-30-2015, 05:29 AM | #6 |
08-30-2015, 05:39 AM | #7 |
i have seen 2 shims used on one side without issue
ck to see whats rubbing first Last edited by Mitch//pa; 08-30-2015 at 08:33 AM. |
08-30-2015, 07:10 AM | #8 |
Hub worn to limits, I always buy new drum and hub assemblies when doing a brake restoration.
Mike |
08-30-2015, 07:35 AM | #9 |
Did you have this problem with the old drums and hubs ? Or is this with new drums and new to this car old hubs ?
Besides the info just given by the fellas, there was a recent post about new studs making contact requiring some judicial grinding to fix the problem. |
08-30-2015, 08:26 AM | #10 |
Yep, hitting the backing plate. Saw the rub mark; just one place about an inch. Thanks.
08-30-2015, 08:29 AM | #11 | |
"studs making contact...grinding to fix" that was me. |
08-30-2015, 01:08 PM | #12 |
I've seen several backing plates with the bottom bent or badly worn, like the car fell off the jack or the wheel came off while driving.
If your's is rubbing at the bottom, maybe the backing plate just needs to be tapped back a little. |
08-30-2015, 03:10 PM | #13 |
Try not to use axle shims. If you can see where it's rubbing follow Tom's advise. Last resort, grind a little off backplate rubbing area. For final rubbing check, push drum in as you rotate and listen. Back off adjuster when checking.
08-30-2015, 03:21 PM | #14 |
Also, with final assembly, make sure axle and hub tapers are grease free. Use lacquer thinner or acetone or brake cleaner with a clean rag, not paper towel.
And thanks again for the measurement help. |
08-30-2015, 03:45 PM | #15 |
I agree with Tom . Make sure your backing plate is seated, tight, and not bent . The use of a shoe centering gauge can help you determine if the backing plate is not right . Try and determine if that's the problem. If all is well shim the axle/Hub with a shim if necessary .
Backing plates take a lot of abuse over the years. Hopefully you can resolve easily Larry Shepard Last edited by larrys40; 08-30-2015 at 03:51 PM. |
08-30-2015, 03:48 PM | #16 | |
I sent the backing plates to one of our vendors to have new roller tracks installed. Something may have happened then |
08-30-2015, 03:56 PM | #17 |
If it were mine, I wouldn't grind anything until I tried the axle shim.
08-30-2015, 03:59 PM | #18 |
I had a drum rub on my parking brake shoe. But yours with rubbing on the backing plate is a little different. Again as said above, Tom's advise looks good to me but after fixing the rub on the backing plate, and if you have it rub also on the parking brake, then your shims work well to fix this problem. Good luck.
08-30-2015, 04:54 PM | #19 |
Problem fixed! "Tapped" out the backing plate in the area it was rubbing.
Thanks to all for your replies and pointing me in the right direction. While it was running, I made an observation. It will be in a new thread. |
08-30-2015, 10:48 PM | #20 |
Glad to hear the fix was easy.
If shims had been needed to correct for a worn taper, I wouldn't be afraid to use one or two shims. |
