07-24-2015, 01:00 PM | #41 |
Re: Oil Filter
Bob, that's just the filter...what about the remote mount gizmo?
RobertB Santa Teresa, NM |
07-24-2015, 08:44 PM | #42 | |
Re: Oil Filter
07-26-2015, 01:38 AM | #43 |
Re: Oil Filter
Bob This Is What Rod Wrote About That Filter Set Up
ROD Post #7 >>> The second filter kit reviewed was the “Timing Gear Cover” partial flow and I do not know if this system is still sold. But the review by “Model A Times” stated “ineffective”. Now What Bob ??? Harley03joe |
07-26-2015, 10:47 AM | #44 |
Re: Oil Filter
07-27-2015, 11:39 AM | #45 |
Re: Oil Filter
Question:
What Are The Pro's And Con's On Installing An Oil Filter ? Should It Be Done On A 31 Ford ? And Why Didn't Ford Put One On The 31 4 Cyl ? What was the first car fitted with a replaceable cartridge oil filter? Answer It Was The 1924 Chrysler. I Wonder Why Ford Left That Important Part Off There Cars ? Maybe Some One Can Elaborate On This Subject Thank You Harley03joe |
07-27-2015, 12:02 PM | #46 |
Re: Oil Filter
07-27-2015, 12:09 PM | #47 |
Re: Oil Filter
07-27-2015, 03:02 PM | #48 |
Re: Oil Filter
If you're following the "guidelines" and changing every 500 mi or so you probably DON'T need a filter. JMO
Paul in CT |
07-28-2015, 09:07 AM | #49 |
Re: Oil Filter
In 1955 a friend of my older brother won a new Pontiac (Canadian) in a draw, that car was the cheapest Pontiac available, 6 cylinder, no oil filter, no radio. You paid extra if you wanted those options.
07-29-2015, 12:14 AM | #50 |
Re: Oil Filter
07-29-2015, 08:42 AM | #52 |
Re: Oil Filter
Do any of you guys know if the valve cover can be welded on? Trying to come up with a leak free entry for the oil back into the valve chamber
07-29-2015, 09:53 AM | #53 | |
Re: Oil Filter
07-29-2015, 10:16 AM | #54 |
Re: Oil Filter
Yeah I can do that but i need a fitting of some sore on the inside of the valve cover to get the oil directed the right way. In the original system the oil is blasted frontward out the dump tube and splashes forward all over the place. I need to replicate this as I will be plugging the stock dump tube. I would like to weld an elbow or something to the inside of the cover.
07-29-2015, 10:56 AM | #55 |
Re: Oil Filter
I would think that just dumping it anywhere in the first chamber would be sufficient. That's what the "A-Ford-Able" filter does.
07-29-2015, 11:33 AM | #56 |
Re: Oil Filter
You're right, I just want to cover all my bases so I can end up with a best possible scenario situation. I definitely want to filter the oil for my new engine...don't want to blow it up either
07-29-2015, 09:21 PM | #57 |
Re: Oil Filter
Ok Carl. I just want to be clear. The a ford able filter literally just dumps the oil straight back into the front chamber? Nothing fancy going on...That makes things easier for me. Probably just over thinking it.
07-29-2015, 09:29 PM | #58 |
Re: Oil Filter
Just removed an A-Ford-Able filter with a remote canister that can be used with headers. Had to cut the tubing to remove it, but it can be made to work. Includes original instructions. Pay the FedEx ground fees and it can be yours for free! PM me.
07-29-2015, 10:43 PM | #59 |
Re: Oil Filter
It's gone! No more PM's please.
07-29-2015, 11:24 PM | #60 |
Re: Oil Filter
So how does the oil line plug into the block?
