04-22-2015, 03:57 PM | #1 |
Adjustable Drag Link
I was taking apart a front end assembly today and came across an interesting drag link. It looked like one end was cut off and one of the ends from a tie rod was threaded on. This would make the drag link adjustable for length. I have not seen anything like this before or in the restoration books.
Ten or 15 years ago I purchased a couple of adjustable drag links that had a turnbuckle arrangement in the middle so you could adjust the length and center the steering wheel. I have not seen them in the catalogs recently. Has anyone else seen one of these drag links with one end that has a tie rod end threaded on? Thanks, Vic |
04-22-2015, 04:15 PM | #2 |
Re: Adjustable Drag Link
Seen? I've made a few like that.
04-22-2015, 04:27 PM | #3 |
A couple years ago an article about how to make one by Wiley Higgins (sp) was in the MAFCA newsletter
This is what I could find http://modelafordclub.co.nz/wp-conte...Box-Aug-11.pdf .. Last edited by Joop; 04-22-2015 at 04:42 PM. |
04-22-2015, 06:31 PM | #4 |
Joop:
Thanks for the article. Vic |
04-22-2015, 07:49 PM | #5 |
Will this work if using a shorten pitman arm?
04-22-2015, 10:20 PM | #6 |
It definitely will. Vic |
04-23-2015, 11:25 AM | #7 |
I made one for my car using a stock drag link, cut and threaded it (one end LH and the other RH) and used the sleeve from a GMC pickup. I threaded the LH end in the lathe before I cut it in half. I also have a shortened pitman arm.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
04-23-2015, 12:43 PM | #8 |
When I was young I decided to try and cut some left hand threads. After about a day and half I finally figured it out. I was so frustrated I was even working between the wall and lathe and my grandfather would walk by and start laughing. I know, its actually easy once you figure it out. But, until then,,,,,,
I had kind of a similar experience learning to weld. I don't need no stinking helmet ! Ever have a doctor peel your eyes like an onion ? |
04-23-2015, 01:38 PM | #9 |
They are not only adjustable for length but can be used for Right hand drive cars OR left hand drive - Do any of our usual suppliers still make them?
04-23-2015, 03:03 PM | #10 |
Never did that but have you ever got a "sunburn" from wearing a white T-shirt while heli-arc welding?
04-23-2015, 03:29 PM | #11 |
John, --- the last supplier here that had them was Sacramento Vintage Ford, they have now discontinued them, they sold for $160 --- I made mine using a used draglink, and this coupler, if you want it I have a spare I could bring home in Sept, probably cost a few pints --- LOL.
Regards Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards. Last edited by Brian T; 04-23-2015 at 03:32 PM. Reason: Added text |
04-23-2015, 03:32 PM | #12 |
04-23-2015, 04:24 PM | #13 | |
Blackwall Panthers Nor Cal chapter |
04-23-2015, 04:59 PM | #14 |
Joop,
Thanks for the link to the drag link article.
Bob Bidonde |
04-23-2015, 05:13 PM | #15 |
12-16-2016, 09:35 AM | #16 |
An outfit called Auto Care and Restoration in Redding California used to sell one for $48 exchange about 20 years ago.
12-16-2016, 12:05 PM | #17 |
It's amazing just how quickly welding can burn you skin. One night I spent a couple hours building a towbar, and the next day my arms and neck were sunburned.
12-16-2016, 01:32 PM | #18 |
I remember seeing a couple of adjustable drag links in the Swap Meet section.
12-16-2016, 01:59 PM | #19 |
See "Machine Girls" entry number 12
I bought one of these when the shortened pitman arm resulted in full lock one way and not the other. Being able to adjust the length of the drag link solved the problem. It's a quality product Keith |
12-16-2016, 02:19 PM | #20 |
I have one of these from the same supplier. I will be putting it on with the short pittman arm whenever I get my truck out of jail [ie: off site storage while my garage is otherwise occupied]
