02-04-2015, 10:20 PM | #41 |
Re: My new 48 F-1
Bump for some tranny info. Will my stock clutch in the 4spd. with the 3 spd?
Respecting and Resurrecting Ford Model A's. |
02-04-2015, 10:26 PM | #42 |
Re: My new 48 F-1
Bigger than it needs to be, but should work fine.
02-04-2015, 10:27 PM | #43 |
Re: My new 48 F-1
Yes, the clutch will work with either. It may have the 11" clutch, the larger trucks do. I would leave it, you are less likely to have clutch chatter with the larger clutch.
Mark |
02-05-2015, 09:59 AM | #44 |
Re: My new 48 F-1
Nice looking truck, when it's done fighting you it will be a great ride.
02-05-2015, 10:36 AM | #45 |
Re: My new 48 F-1
It looks stock I had a 48 f-1 and it was alot a fun!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
02-05-2015, 11:37 AM | #46 |
Re: My new 48 F-1
02-05-2015, 11:47 AM | #47 |
Re: My new 48 F-1
He might of been saying you should swap the flywheel and clutch assembly, which is not bad advice. But you do not "have to" swap them. Your current setup is way heaver than is needed which reduces acceleration, is harder to use, etc. But if you are just wanting to drive it around and are not concerned about performance it should be fine.
02-05-2015, 08:45 PM | #48 |
Re: My new 48 F-1
How much of a noticeable difference can it be though? The whole reason I am doing it is because number one, I am used to 3spds. and I live in an area that is pretty heavily congested. If I was out in the sticks I might opt on keeping it. I also hate double clutching, I hated it so much in my model a that I swapped in a 39 trans with a clings adapter. Best thing I ever did.
02-05-2015, 10:07 PM | #49 |
Re: My new 48 F-1
The 11" pressure plate weighs 2 pounds more than the 10". The clutch discs are probably a pound or less different. You would never notice the difference. The 11" clutch will work just fine.
Mark |
02-05-2015, 10:50 PM | #50 |
Re: My new 48 F-1
Sorry to disagree but there is a big difference. It has to do with where that weight is located and momentum and acceleration. There is even a big difference between a 10 inch clutch and a 9 inch clutch setup. I would never go larger than a 9 inch myself. The 11 inch will work and may be fine for the application, but you can't say you won't notice the difference because you will!
02-06-2015, 07:52 AM | #51 | |
Re: My new 48 F-1
I just swapped a 4 speed for a HD 3 speed. I used the 11" clutch. Stop and go traffic aint no big deal. |
02-06-2015, 10:46 AM | #52 |
Re: My new 48 F-1
For a truck as heavy as it is and especially if you are going to use it as a pickup I would leave the 11". An inch bigger clutch will not make or break anything.
Thee Inland Emperors |
02-06-2015, 11:08 AM | #53 |
Re: My new 48 F-1
In my low (37,000) mileage '48 F-1 I replaced the 4-speed crash box with a regular (light-duty) three-speed. Kept the original clutch - didn't even take it off the flywheel. Drives like a new truck! Very happy. If it ain't broke don't fix it!!
02-06-2015, 11:57 AM | #54 |
Re: My new 48 F-1
excellent, thanks for the feedback guys. do you guys leave your spring packs alone when it comes to the ride of the truck. She seems very stiff with all those springs in there. I am going to be hauling with it occasionally but nothing too heavy.
02-07-2015, 07:42 PM | #55 |
Re: My new 48 F-1
Another question for you guys, how do I get the ignition switch out? Does the bezel hold it on? Can't seem to figure it out.
02-07-2015, 11:27 PM | #56 |
Re: My new 48 F-1
IIRC, it has been a while since I took mine out. Push the back of the switch toward the dash, like you are trying to push it thru the hole from the back. Turn the stainless bezel and pull it off, then take the switch out from the back. I can look tomorrow afternoon and double check.
Mark |
02-08-2015, 12:45 PM | #57 |
Re: My new 48 F-1
The bezel should snap off. Then get behind the switch and push it towards you and turn it to clear the hole in the dash. It's actually not very hard if you do it right.
02-17-2015, 08:56 PM | #58 |
Re: My new 48 F-1
Got it off, thanks guys. Is there any source on the correct screws that hold the door inspection panels on? They are a counter sunk flathead sheetmetal screw. The vendors are Phillips head. I went to a local hardware that has everything but they didn't have them.
02-18-2015, 06:18 AM | #59 |
Re: My new 48 F-1
Sacremento Vintage Ford has them,but they are shiney chrome.
02-18-2015, 11:47 AM | #60 |
Re: My new 48 F-1
Yeah and that won't cut it on my truck. They need to be original. Might have to put a wanted ad out for some.
