12-11-2012, 05:42 PM | #1 |
T5 Ranger Transmission-in Model A
Has any one put a ford Ranger T5 Transmission 5 speed in a model A ford and can anyone tell me where to go to get information on the installation
Thanks for you help |
12-11-2012, 05:49 PM | #2 |
Re: T5 Ranger Transmission-in Model A
This has been discussed before. I believe you can do a search for some of those threads. Many have done this swap. It takes a special kit...
12-11-2012, 06:51 PM | #3 |
After I made the post I found information posted Sorry I cause anyone any trouble.
Thanks |
12-11-2012, 07:23 PM | #4 |
This form is for asking questions about your a. Don't every be sorry for posting here. The t-5 was used in several cars and trucks including the mustang.
12-11-2012, 08:14 PM | #5 |
The s10 trans is the most widely used due to its more forward mounted shifter.
12-11-2012, 09:52 PM | #6 |
12-11-2012, 10:31 PM | #7 | |
Pete's Ponies Mustang RUSToration & Performance |
12-11-2012, 11:11 PM | #8 |
my s-10 has the tower at the front edge of my seat . fits perfect .
V4f |
12-12-2012, 06:41 AM | #9 |
What years Ranger transmissions work for this conversion. I have access to several 93-94 models.
12-12-2012, 11:16 AM | #10 |
The Rangers from 1989-2000s used a Mazda 5 speed (M5OD) trans with a cast aluminum case that was unitized with the bell housing. (Some 1991-earlier ones used the Mitsubishi 5 speed that has a removeable bell housing.)The 1988-1996 F150 had the same Mazda trans, but the case bolt pattern varied across engine configs, as did the Ranger. So, adaptation would be tricky with a non-removeable bell housing. The earlier F150 Tremec conversion has been mentioned before as one that "looks" close to original.
http://fordbarn.com/forum/showthread...highlight=f150
Thanks, Mark in SC "We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it. |
12-12-2012, 06:20 PM | #11 |
MikeK, who makes/and-or sells those gearbox lever re-positioners for the T5?
AL in NY |
Thread Tools | |
Display Modes | |
