Old 08-23-2012, 11:48 AM   #1
CaptDD
Default Throttle Linkage attached to Engine
First of all Hello!!! to the community. I am new here and am in the process of semi restoring a 31 Coupe.
With this Coupe I received some spare parts. One of the parts that I need to correct is the Throttle Linkage attached to the Engine. The one in the car was broken at the pedal end. There are no threads to attach a pedal. I did receive one as a spare which is broken at the drivers end and missing the linkage for the steering column control.
A few pictures to eliminate the 1000 word post;
http://www.captdd.com/ModelA/IMG_0321.JPG Full Size Image
http://www.captdd.com/ModelA/IMG_0322.JPG Full Size Image
http://www.captdd.com/ModelA/IMG_0323.JPG Full Size Image
I'm planning on removing the good throttle linkage from the broken bracket and placing it into the good bracket.
Question: Would the best method be to heat the end with the linkage ball and straighten it so that it will feed out of the bracket?
CaptDD is offline   Reply With Quote
Old 08-23-2012, 12:58 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Throttle Linkage attached to Engine
I would look for another one. JMO
Paul in CT
Old 08-23-2012, 01:03 PM   #3
Bob C
I just cut the head off of a bolt and welded it on.
Bob
Old 08-23-2012, 04:06 PM   #4
CaptDD
Thanks Bob!! Hadn't thought of that even though I have a MIG. Length is not an issue as I have the other for comparison.
Old 08-23-2012, 04:25 PM   #5
wrndln
These linkages are quite plentiful. You should be able to get one of $15 or so. I have 5 or 6 myself. I think it would be much easier to use a different one than is not damaged.
Rusty Nelson
Old 08-23-2012, 06:19 PM   #6
1931 flamingo
wrndln: PM sent
Paul in CT
Old 08-23-2012, 07:13 PM   #7
CJH
Call Bert's Model A Center in Colorado. They should be able to set you up with a good one.
Good Luck,
Chris
" . . . these changes aren't permanent, but change is." - Neal Peart
CJH is offline   Reply With Quote
Old 08-24-2012, 10:11 PM   #8
Bill in SoCal
Bill in SoCal's Avatar
Before you remove the accelerator assembly from the car, check to see if there are any shims between the flywheel housing and the engine block where the two accelerator assembly bolts pass through and connect to the engine. Sometimes there are horseshoe looking shims placed there to help align the flywheel housing to reduce clutch chattering. Often they are stuck in place by old grease and dirt, but they are easy to dislodge.
I would replace the old assembly with a good original as suggested.
Bill in SoCal is offline   Reply With Quote
Thread Tools
Display Modes
