07-01-2012, 05:23 PM | #1 |
1940 clutch adjustment problem
I have a 1940 Tudor 221/3 speed, all stock (jalopy)
Installed a flywheel,disc,preasure plate, throwout bearing all new guarenteed to be the right parts and they match the old parts. Now clutch adjustment has 5'' of free play at top of pedal with adjustment all the way out, and bearing barely touches throwout bearing. What could be some possible problems ? would the pedal assembly need rebuilt ? at a loss, any suggestions CR. |
07-01-2012, 05:34 PM | #2 |
Re: 1940 clutch adjustment problem
Did you ck the fingers on the P/plate before you stuck the tranny back on??
paul in CT |
07-02-2012, 01:38 AM | #3 |
I ran into a simular problem once. Turned out I had a Borg &Beck style Pressure plate and not the Long style. I put it all together and couldnt get it in gear because the clutch wouldnt release.
07-02-2012, 02:44 AM | #4 |
I had same problem on my 49 F1. After trying I dont know how many things I took a spare clevis rod and lengthened it. That's probably not the way to go but that was 5000 miles ago and it works great.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
07-02-2012, 07:14 AM | #5 |
IF all the parts are correct be sure the pressure plate is not in backwards. If that's OK then check the engine, transmission alignment in relation to the cars frame. I little misalignment can play havoc with the adjustment.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
07-02-2012, 07:33 AM | #6 |
07-02-2012, 12:49 PM | #7 |
I was thinking the same thing as JWL
Mike
"There is no 'normal life'; there's just life." - Doc Holliday from the film Tombstone |
07-02-2012, 01:04 PM | #8 |
Well if you accidentally left the pressure plate setup spacers in place that would give an excessive throw on the pedal. That's easy to check with the engine off just put the car in gear and give it a push, if it rolls you know the clutch is in the disengaged position. If they are still in place as per JWL's post they may be accessed by popping the inspection cover and not removing the trans.
dickspadaro.com |
07-02-2012, 02:59 PM | #9 |
I like Dick's thoughts... and also, make sure your equalizer shaft has both bolts in it as if there is one missing, stripped, hole elongated, etc, it doesn't take much to shift that which effects the clutch pedal. I've had/seen that problem a couple of times.
There are two bolts on the from that hold the equalizer shaft. Check them out! Larry S. |
07-02-2012, 03:00 PM | #10 | |
07-03-2012, 06:19 AM | #11 |
Walts right, I forgot about the x member. On my F1 you could make longer clevis but on my 41 it would hit the x member.
07-03-2012, 08:31 AM | #12 |
I found on a lot of 39s the pedal hits the bottom of the wood floor board limiting the clutch travel. I removed some wood letting the pedal come up higher and that solved the problem. G.M.
www.fordcollector.com |
