Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 07-17-2021, 09:52 AM   #1
Dave H
Default Gordon Smith Model A compressor chassis
City: Vienna
State: Virginia
NOTE: I goofed, the following should be under FOR SALE, NOT "wanted".
This is from a compressor that apparently had been built using a period Gordon Smith Model A conversion kit. It consists of a cut down Model a frame with an un cracked front cross member and is weathered but solid, the hitch assembly with a tube for a pipe stand, and the spring and axle attaching brackets, missing one plate. Most other associated Model A parts to complete the chassis could be furnished here at additional cost. There are no actual compressor parts. Use this to build up a Gordon Smith air compressor or to build a period Model A trailer. It could also be used for a stationary or portable engine test stand, or the trailer hitch part could be used separately for a Model A tow bar. Pick up here, zip 22181. $100.
Thanks for reading, Dave 703 938 8954
Dave H is offline   Reply With Quote
