02-24-2021, 07:24 PM | #1 |
Brake drums
Can anyone tell me who sells new brake drums for a 40 Ford axle backing plates? What backing plates do I need to use buick drums
02-24-2021, 07:28 PM | #2 |
Re: Brake drums
Can anyone tell me who sells brake drums for my 40 Ford. Also what backing plates do I use to run Buick brake drums?
02-24-2021, 07:43 PM | #3 |
Re: Brake drums
Boling Bros. sells excellent quality replacement 40 Ford drums for use with 40 Ford backing plates.
02-24-2021, 07:54 PM | #4 | |
Re: Brake drums
You might consider these MT Car Products (Boling Bros.) Buick repro bolt-on drums (bolt-on to stock '40 Ford front hubs after replacing studs). Read description. NOTE: "Krylon32" member on this FordBarn is a dealer and gives members here a 10% discount. GREAT guy to deal with! Boling Bros. site with info: http://www.bolingbrothers.com/buick-...m/#description Contact: "Krylon32" is: Gary Mussman 122 Southern Hills • Hebron, NE • 68370. Phone: 402-749-1932 |
02-25-2021, 01:36 AM | #5 |
Re: Brake drums
It'd be great if someone desired to make wide fives drums. There would be a lot of people on that bus. Maybe not as cool as "fined" drums.... but racing has adapted them so wide five has a bit of a following.
02-25-2021, 05:38 AM | #6 |
Re: Brake drums
https://www.speedwaymotors.com/Buick...4aAoq4EALw_wcB |
02-25-2021, 09:54 AM | #7 |
Re: Brake drums
They better be good at that price!
02-25-2021, 12:27 PM | #8 |
Re: Brake drums
I don’t think the Speedway drums will work. The amount of flange outside the studs is less than Ford used. Stock Ford wheels will not have outside support.Compare the flange on the drum to the flange on the hub.
02-25-2021, 02:35 PM | #9 |
Re: Brake drums
[QUOTE=jrvariel48;1989171]I installed the MT Products front brake assembly including the cast drums. It's excellent and installs very easily. Speedway makes a nice aluminum Buick style drum. I asked MT if they fit their set up, but they didn't know. Is anyone running these? Maybe Gary (Krylon32) will jump in.
Joe....As I'm sure you must be aware by now, the "MT" stuff is not only nice...it's "Top Shelf"! Curious as to why you'd consider the Speedway Buick drums over the "MT" Buick drums. The MT Buicks are obviously engineered to work with the rest of the MT stuff that you already have. Here's a little bit of info I have garnered in the past. This info came from a survey that a Speedway customer wrote 'somewhere' that I can't remember now, which I came-across in the past three months. A Speedway technician admitted to the customer that their "Lincoln" brake backing plates and hardware was in fact "MT" sourced. The technician also added that their "Lincoln-style" drums were sourced "elsewhere", which I concluded to mean possibly the far side of the Pacific Ocean. I have read first-hand of quite a few people experiencing 'out-of-balance' and 'out-of-round' problems with the Speedway Lincoln-type drums. The price difference might prove the old adage...."Ya get what ya pay for!" Just looking at the two different Lincoln-type drums side by side, there is no comparison. Along the same lines, the Speedway Buick drums just don't look anything like the quality of MT's Buick drums. From Speedway's own pictures, there are obvious casting flaws (pics below). You couldn't pay me to use those 'cheap', 'Speedy' Buicks. And I would have to imagine that MT Buicks are engineered to work with the rest of the MT line. Check the Boling Bros. site below on the Buick drums, making sure to read the "FULL DESCRIPTION". I assume that you realize "MT" and "Boling Bros." are essentially synonymous. DD http://www.bolingbrothers.com/buick-...in-brake-drum/ Last edited by V8COOPMAN; 02-25-2021 at 02:47 PM. |
02-25-2021, 02:51 PM | #10 |
Re: Brake drums
I know nothing about the Speedway Buick drums but have used some of the MT Buick style drums. I would wait on the plain drums from MT as their quality is much better than Speedways replacement drum. They are currently out of plain drums until late April last time I talked to them. Still giving 10% off all MT products. Krylon32
02-25-2021, 05:29 PM | #11 | |
Re: Brake drums
[QUOTE=V8COOPMAN;1989381]
02-25-2021, 05:30 PM | #12 | |
Re: Brake drums
Thanks |
02-25-2021, 05:58 PM | #13 |
Re: Brake drums
It sure is nice to have an US-made option for brake drums. They are machined extremely well and a quality product for sure.
I was surprised how much more weight a fully cast drum is compared to a OEM Ford one that has a stamped steel center welded in. It was a significant difference. Not sure it matters, but that's my observation. |
02-25-2021, 06:53 PM | #14 | |
Re: Brake drums
Contact: "Krylon32"..."Cornhuskers Rod & Custom" Gary Mussman 122 Southern Hills • Hebron, NE • 68370. Phone: 402-749-1932 |
02-25-2021, 08:14 PM | #15 | |
Re: Brake drums
02-25-2021, 09:27 PM | #16 |
Re: Brake drums
02-27-2021, 04:00 AM | #17 |
Re: Brake drums
JG Brake drum relining does a great job if you want to keep yours. they are on the web. top notch American company.
02-27-2021, 06:17 AM | #18 |
Re: Brake drums
I've noticed that some people offset the rims to display their beautiful Buick drums. This changes the "King pin inculcation". This puts undue strain on the spindle shaft, and makes the steerig more sensitive to the little bumps in the road. Just an unsafe condition. "Aesthetics can kill"
Gramps |
02-27-2021, 03:03 PM | #19 | |
Re: Brake drums
Actually, the "king pin inclination" does NOT change, although offsetting the rims outboard DOES put undue strain on the king pins (among other components) because of the leverage effect. What DOES change with offsetting the rims is the "Scrub Radius". The scrub radius would essentially be "ideal" when the EXTENDED CENTERLINE of the king pin intersects the CENTER of the tire tread (left to right) at the road surface, as seen below. DD |
02-27-2021, 05:32 PM | #20 |
Re: Brake drums
I do believe the Buick-finned type Ford drums are designed to have the fins showing with no wheel offset.
Personally, I can't stand the look of brakes when guys do that. Kind of like having your designer boxers hanging out of your jeans. Tuck that crap back in where it belongs. |
