Old 07-28-2020, 08:29 AM   #1
denns1989
denns1989's Avatar
Default "8BA" Crank Pulley Car/Truck Inquiry
I had this post earlier:
https://www.fordbarn.com/forum/showt...91#post1899791
I have since discovered that the incorrect crank pulley nut was used (basically it would almost pass thru the bore of the pulley !) Currently I don't have a spare truck pulley but I do have a 52 Merc Car pulley, It appears the bolt & washer from the merc engine are what I need on the motor (they are all the same for that era it appears, obviously the Merc pulley is a narrow belt pulley, is the spacing the same from a 52 truck motor to a 52 car motor for example ? I assume the merc pulley will fit on my motor, wondering if I could just run narrow belts, but not sure if the car crank pulley belt grooves align to the truck water pumps, fan & genny, I don't think the wide truck pulleys will care if a narrow belt is running in them, but the offset is a whole other issue... The 52 pulley is an hour away from me right now so I thought I would do some pre investigation.
denns1989 is offline   Reply With Quote
Old 07-28-2020, 08:57 AM   #2
flatford8
flatford8's Avatar
Default Re: "8BA" Crank Pulley Car/Truck Inquiry
A v-belt grips by the sides of the belt. A narrow belt running in a wide pulley may be ok to “get you home” but I don’t think it’s gonna work for a long period. Should be plenty of those pulleys around.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 07-28-2020, 10:24 AM   #3
super flat
super flat's Avatar
Dennis if you can not find one locally I will pull one and send it to you! I am Roadster1927 on the hamb. Gary
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 07-28-2020, 01:09 PM   #4
denns1989
denns1989's Avatar
Thanks Gary ! I will let you know, much appreciated.
Old 07-28-2020, 02:43 PM   #5
19Fordy
19Fordy's Avatar
All pulleys need to be the same size to match.
Old 08-17-2020, 08:55 AM   #6
denns1989
denns1989's Avatar
Sourced the correct pulley including proper 7/8" bolt with washer from a "bush find" truck motor - All back together & working properly.
Thread Tools
Display Modes
