Old 06-27-2020, 03:35 PM   #1
JOHN CT
JOHN CT's Avatar
Default Emergency brake handle
My emergency brake stopped locking into place. I did have it adjusted so when I pull it back 3 clicks it locked well. Never had a problem it worked fine. Out of the blue it won’t catch. I took a look and the ratchet and paw is worn.
The reason I’m telling you this is I been replacing ratchets and paws about every 5 years!! It’s my third time. When I set the brakes I don’t drag the paw. What the.....! Is anyone else having any problems with the materials they are using?
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 06-28-2020, 10:12 AM   #2
Will N
Will N's Avatar
Default Re: Emergency brake handle
I've never had to change those parts, and I've had my car for 23 years now. Maybe try changing the vendor you are buying them from? They might use a different supplier. You might also try heat treating them to harden the parts. Heat to cherry red and quench them quickly in oil. If the steel has enough carbon, this will harden it.
Will N is offline   Reply With Quote
