Old 05-12-2020, 08:25 PM   #1
jmerson
Default '75 pinto 10" rotor and caliper
I'm sure this has come up in the past but i searched for it and got nothing. I have a '34 sedan with mustang front end. The caliper has a casting number 4109 and an emblem " Ford". It has a 10" rotor that was a 4 bolt rotor but it has been redrilled for 5 studs. I measured it and got 4.25" spacing but maybe i measured wrong because all i can find for 10" is either 5" or 4.75" or 4.5". Any one have any experience with this setup??
I want to get new rotors, calipers and pads.
jmerson is offline   Reply With Quote
Old 05-12-2020, 08:43 PM   #2
Charlie Stephens
Default Re: '75 pinto 10" rotor and caliper
I don't think I have ever seen this topic in the past. You would probably have better luck on HAMB: https://www.jalopyjournal.com/forum/...ssage-board.5/
Good luck.
Charlie Stephens
Old 05-12-2020, 11:34 PM   #3
Lanny
Lanny's Avatar
While some newer Fords do use a 5 lug 4.25" bc., there is Good Chance you
are probably measuring wrong.
Because there is NO Stud 180 degrees across on a 5 lug bc. pattern you
measure the way the picture diagram below shows.
I live on tuff street, the further ya go,
the tuffer they git,
I live in the last house on the block !!!
___________________________________________
You bet ya, I wear the pants in My family --------
So What, if She tells me which ones to wear ?
Lanny is offline   Reply With Quote
Old 05-13-2020, 12:50 AM   #4
mobileparts
I have N.O.S. D90 / 7026D90 ++ Asbestos ++ Brake Pads -- if you would like the nicest, softest, smoooooothest braking system Brake Pads known to mankind...
Always best to simply call me --- Craig --- 516 - 485 - 1935..... New York....
mobileparts is offline   Reply With Quote
Old 05-13-2020, 08:57 AM   #5
TJ
TJ's Avatar
Your best bet is to take your rotors, calipers and pads to your local Napa Auto Parts and have them cross reference the parts. If you have the standard Pinto/Mustang II spindles it should not be difficult to get parts. You can also research e-Bay and find what you need.
Thread Tools
Display Modes
