Old 03-26-2020, 01:30 PM   #1
poolplayer1
Default 55 ford Ranch wagon/ LED question?
I am thinking about replacing the 1157 tail light bulbs with led bulbs but was wondering if I need to change out the flasher too. If yes,is there any problems finding the flasher for this 55? It is already converted to a 12 volt system.
Thanks for your help.
poolplayer1 is offline   Reply With Quote
Old 03-26-2020, 02:01 PM   #2
fordy_nine
Default Re: 55 ford Ranch wagon/ LED question?
It probably will work without changing the flasher. If a special flasher is needed, electronic flashers are available. Check at auto parts store........Bob L
fordy_nine is offline   Reply With Quote
Old 03-26-2020, 07:19 PM   #3
miker98038
miker98038's Avatar
I haven't looked into this in some years. But early on with LED's you needed a different flasher, and they were a 3 wire. 3rd wire was ground, IIRC. The original wiring on my bird was a 2 wire and the flasher was in a clip by the steering column as I remember. So running the 3rd terminal to ground should solve it.
Edit. I went and looked, Jets shows them for both 2 and 3 terminals now.
https://www.jegs.com/p/JEGS/JEGS-LED...72412/10002/-1
miker98038 is offline   Reply With Quote
Old 03-27-2020, 12:25 AM   #4
50fordcoupeman
50fordcoupeman's Avatar
Miker........you are correct. I put them in my 12V avatar and all I did was to install the bulbs-nothing else.
50fordcoupeman is offline   Reply With Quote
Old 03-27-2020, 04:08 PM   #5
poolplayer1
Thanks to all for your help. I will get the parts and install them.
