Old 03-22-2020, 12:07 PM   #1
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Default Painting whitewalls black
My 1931 all black Tudor came to me with whitewall tires and almost white cream colored wheels. It also has dual fender mounted whitewall spares.
I am contemplating using tire black on the whitewalls to kinda tone the overall contrast and and give the car a more period look.
I am surmising once you use tire black on whitewalls there is no turning back. And maybe the tire black might not work as well as I am hoping.
Has anyone else gone down this road before?
fried okra is offline   Reply With Quote
Old 03-22-2020, 12:29 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Painting whitewalls black
Hollywood art directors would spray whitwalls with a hair product called tips and streaks or streaks and tips. it was not a permanent fix, temporary only and would eventually wash off.
Tacoma Bob is offline   Reply With Quote
Old 03-22-2020, 12:34 PM   #3
Vic in E-TN
Smile Re: Painting whitewalls black
A few years ago I saved a friend who had the same problem as you some money. Take the tires off the rims and reverse them with the whitewalls on the inside.
Vic
Vic in E-TN is offline   Reply With Quote
Old 03-22-2020, 01:25 PM   #4
Chris in WNC
Chris in WNC's Avatar
I reversed whitewalls last year on our '35 to make it look better.
Spray the white with black satin Rustoleum while they are off the rims.
"Every Model A looks 100X better with blackwall tires" - that's my story and I'm sticking to it!
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 03-22-2020, 01:58 PM   #5
MikeK
MikeK's Avatar
And then there are those who point to the whitewalls in several color Ford advertisements and love them. Dealer installed option! I remember in High School (60's) painting white walls on blackwalls with a concoction from Warshawsky's on South State Street in Chicago.
MikeK is offline   Reply With Quote
Old 03-22-2020, 03:54 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I first turned the whitewall facing the inside . I painted over the white part with satin black paint in a spray can .
Old 03-22-2020, 04:21 PM   #7
jb-ob
I greatly support you good taste.
Firestone tire dealers have a black spray which they use to cover raised white lettering when not wanted. Doesn't good bad either.
Unless you reverse the tires, try not to 'curb' them after painting.
jb-ob is offline   Reply With Quote
Old 03-22-2020, 05:07 PM   #8
dlfrisch
dlfrisch's Avatar
On my newest project, I’m rebuilding (frame up) ‘28 Sport coupe. Both front fenders have spare tire wells. The two existing spare tires have been mounted (reversed)with the white wall side on the inside. The tire tread is good - they are a little checked, but I think they are in good shape. I would rather not have to buy new spare tires. I would like to paint that white side black. What kind of paint should be used?
dlfrisch is offline   Reply With Quote
Old 03-22-2020, 05:09 PM   #9
Synchro909
Synchro909's Avatar
I've tried several things to hide the wretched white wall that were on one of my cars when I got it. None worked well and strangely, the same number were permanent.
I eventually gave up and drove the tread off them only to have the value of our $ turn to turds. Now, replacing them even with black walls is out of the question.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 03-22-2020, 05:20 PM   #10
Bick in New Zealand
Bick in New Zealand's Avatar
I remember here years ago, when Firestone was making tires and exporting them, you couldn't buy the whitewalls for some reason, but someone quickly discovered they were covering the whitewalls with a black solution to disguise them for the local market. Out with the prepsol / thinners, and presto you had a set of whitewalls, which were the rage on As and early V8s at the time.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 03-22-2020, 05:51 PM   #11
Dodge
I used rubber bumper paint (spray) it is somewhat flexible and has held up well.
Works for steering wheels also....
Dodge is offline   Reply With Quote
Old 03-22-2020, 09:20 PM   #12
mrbilman
I would recommend Tire Paint from Miller Tire. If you turned the tires so the white is in and paint with this it would be very hard to tell they were whitewalls.
https://www.millertire.com/products/...ck-tire-paint/
mrbilman is offline   Reply With Quote
Old 03-22-2020, 09:52 PM   #13
duke36
I use Millers also; it's water based. The whites need to be super clean . Millers also works on rubber runningboards.
duke36 is offline   Reply With Quote
Old 03-23-2020, 12:49 PM   #14
ronn
I inverted my whitewalls on my 22 Baby Grand yrs ago. dont mind that the insides are white..............
Old 03-23-2020, 03:11 PM   #15
31Abone
31Abone's Avatar
Had an old can of Dupont #7 tire black ..worked real good..tires looked like black walls ..no white ever showed thru after one year..then I bot new blacks....sc
31Abone is offline   Reply With Quote
Old 03-23-2020, 05:09 PM   #16
mass A man
mass A man's Avatar
Just another thought, how about the fairly new "Flex Seal" paint in a small can. It's black and dries like rubber.
mass A man is offline   Reply With Quote
Old 03-23-2020, 05:13 PM   #17
old31
i guess some Grecian formula would work.
Old 03-23-2020, 09:25 PM   #18
fried okra
Thanks group, I will check into the Miller Tire paint, Dupont #7, and Flex Seal for a near term solution.
Old 03-28-2020, 10:32 AM   #19
DHZIEMAN
I found a product on the web I ordered and used on two white wall tires that was done two years ago and the tires had the ww turned in and this product has been run in the rain and has been holding up well. I am adding a picture of the container. Warning!! Don't get this stuff on anything but where you want it. It is permanent! It is called m. e. Miller tire "BLACK TIRE PAINT! It is water based and cleans up ok! But it stays on rubber very well! Cannot seem to upload the photo. Will try by email to your account.
DHZIEMAN is offline   Reply With Quote
Thread Tools
Display Modes
